Track Day (Oulton Park) in 3.2 v6
foxterrier Aug 6, 2011
  1. foxterrier
    foxterrier New Member
    15
    Hi Guys,
    Advice really. As title, doing track day in October.
    Thinking about what prep I could do in my car, bearing in mind it also gets used every day for work so nothing too drastic.
    Possibilities so far :-
    Improve handling - poss Koni FSD dampers and lowered springs (had this combination on last car - loved it)
    or
    Improve braking - Black Diamond Disc and Ferodo 2500 pads.
    or roll out boat and do both.
    Any suggestions?
  2. salad.dodger
    salad.dodger Member
    68
    i would certainly uprate the brakes, never a bad thing, although i dont know what standard are like on your car.
    lowering and stiffening the chassis is good, you wont get to much body roll.
    good tyres, road legal slicks maybe
    fire extinguisher
  3. foxterrier
    15
    Thanx for that - I hadn't even thought about a fire extinguisher.
  4. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,276
    165
    Brakes are good in the 3.2 anyway. shell V power for a tank or 2 leading up to your day is worth 10 bhp on your car. Tyre pressures at 40psi if you are on 18's, check oil. Wouldn't worry about the rest. i expect you will back off before the suspension backs off :) I did a track day at Goodwood in my 3.2 and it was fine as it was.
  5. G111MDS
    G111MDS Member
    68
    check your tyre pressures after the first few laps or so when they're warmed up as you may need to let some air out. I did a track day at Le Mans Buggati at the end of May and couldn't believe the reading i was getting! It was a warm day mind you...
  6. Matt_S
    Matt_S Member
    92
    Consider a higher temp brake fluid, especially if its due a change anyway.
  7. G111MDS
    G111MDS Member
    68
    Motul RBF600 is what has been recommended to me for replacement and will be going in my other car whilst its off the road for the winter :)
  8. foxterrier
    15
    All good info - Thanx chaps
