Track car issues - help required
S3 TAM Sep 25, 2012
  1. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Do u think he should buy it then?
    Is there a dummies guide to coding the ecu to clocks guide floating around?
  2. S3 TAM
    624
    10
    What about the pin/skc number is this not required?
  3. badger5
    9,601
    2,060
    go onto ross tech, search immo 2, simple instructions there
    no need for skc etc etc this is immo2 in ibiza not immo3
  4. S3 TAM
    624
    10
    OK bloke selling ECU was dodgy.
    He wanted bank transfer no paypal shizzle and i'm not down with that. lol
    for temp measures would it be safe to pull a couple of degrees in unisettings - while he get the cash together for a remap?
    Edit:
    any one got any ideas to why it's pulling timing like that?
  5. Westy
    Westy Well-Known Member
    17,443
    1,105
    Pulling timing due to fuelling being stock is my guess. Have you tried bringing the boost down to whatever a stock Ibiza runs?
    Will the car be ready in time for our Bedford trackday?
  6. S3 TAM
    624
    10
    It better be.
    The hours we have put into it in the last 6 weeks....
    I was thinking to take a degree or 2 off in unisettings and see what that does with the figures, but I would like to know what implications that may have.
    don't really want to reduce the boost. if we have to then we will.
    looks like a remap is on the cards asap
  7. Westy
    17,443
    1,105
    Have you done any fuel logs yet to see what the fuelling is doing? I might be running mega lean which may explain the timing pull?!
  8. S3 TAM
    624
    10
    Could well be?
    What m block do I log for fueling?
    might shove a 4 bar reg in to see what it does
  9. Westy
    17,443
    1,105
    Block 31 is Lambda and 32 shows the current fuel trim percentage. pop it into this spread sheet:
    http://www.ross-tech.net/vag-com/examples/air_fuel_EXAMPLE.xls
    If you do a log with 031, 115, 020 together you can see what the fuelling is doing under boost and where the timing is being pulled.
    Also what are the AITs (118) like?
    Mate you're loosing your touch since the days of our late night mech sessions :moa:
  10. S3 TAM
    624
    10
    I know matey i haven't used vcds for so long i forgotten what the odb port looks like.
    AIT's are fun fuc**ng tastic. the other night we were seeing 16's.
    don't forget it's only a teeny weeny blower...
  11. badger5
    9,601
    2,060
    this is an ibiza
    narrowband ecu
    aka dumb ass thing
  12. Westy
    17,443
    1,105
    Stupid ECU.
    I've just been told by Tam that they have bought, fitted, and coded an ECU with revo stage 2 on it. They will be going out to log later.
  13. S3 TAM
    624
    10
    Quick update.
    The new Revo stage map'd ecu is awesome much better map. so smooth compared to the old one and the power delivery is much better. The car truly is a pocket rocket. with a couple of **** launches saw saw 5.6 secs 0-60.
    also completely destroyed a BMW 330.. suck on my eggs bimmer
    The old ecu had been chipped as it had a load of silicone sealant round it.
    If its a narrow band ECU do i need to change the fueling in Revo?
    Currently running Boost 7 Timing 5 Fuel 8!
    0 timing pull on all 4 pots. like nuffin at all.
    will post up some new log's when we get it out again...
  14. badger5
    9,601
    2,060
    nothing to change in revo.. fueling wise it is what it is....
    timing and boost is adjustable in revo
  15. danderton
    danderton Member
    84
    Hi,
    I have the same problem with my N75 and wiring and search prompted this thread. Did you rewire the cables back to the ECU? (I assume that where they go) or just a section.
    Any tips in doing so? How long did it take and is there anything to watch for? I ideally don't wanna follow it all the way back to find its common to break in a certain location.
    Any ideas or tips would be gratefully received.
