TQS track car project - extremely slow progress
slepy Mar 16, 2014
  1. Broken Byzan
    13,237
    465
    Red led on mine. Or fis on dash. I have a stack oil pressure gauge with red back light but would love the stack white. But those are the professional 150 each ones. Ouch
  2. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,085
    321
    Yeah bit expensive. Think I will get the glowshift. Unless my gf wants to splash out for prosport halo :)
  3. PaulJC84
    PaulJC84 Owner
    2,890
    13
    I use the awe boost gauge. The light colour matches the interior quite well.
    Under boost it does sometimes buzz though, apparently that can be fixed with a bike fuel filter or similar.
  4. slepy
    2,085
    321
    The white shadow pro 2 on ebay looks good. They do it only in bar though.
  5. slepy
    2,085
    321
    I'm selling my seats now. Does S4 have different front seat mounts?
    Broken Byzan likes this.
  6. Broken Byzan
    13,237
    465
    Same mounts yes. And drop in on a car with electric lumbar support
  7. slepy
    2,085
    321
    Ok. Thanks.
  8. slepy
    2,085
    321
    Managed to order the wires and plug for n75 from audi. Only £2 each. Also getting new DV710N.
    The hose that goes from manifold to DV was a bit of a guesswork to find as the guy didn't have a clue which one. I've ordered one that comes on a 5m roll. Hope that's the one!
  9. slepy
    2,085
    321
    Anyone needs an airbag or the whole wheel?
    After 3 weeks of waiting I finally got the hub to fit my bargain sparco 330mm steering wheel.
  10. PaulJC84
    PaulJC84 Owner
    2,890
    13
    Are you planning on using the horn and a resistor to put the airbag light out?
    I got another harness to save cutting the original and am planning on using the wires to hopefully have a working horn and no airbag light.
    Think the resistor for the steering is 4.7ohm and the seats need 2.2ohm.
  11. slepy
    2,085
    321
    Well, I will need to work out how to wire the horn. I believe there are two green wires going to the wheel which need to be connected to the horn? I might just get same size wires from halfords and extend them to connect to the wheel.
    I will be removing seats and all other airbags and was thinking just to take the clocks out and cover up the airbag light with black tape. Just not sure how it will work with mot but have a whole year to worry about that.
    Can't wait to rip out all the interior.
  12. slepy
    2,085
    321
    Just these green ones or the third one next to them as well?
  13. PaulJC84
    PaulJC84 Owner
    2,890
    13
    I think the horn uses the purple (+) and green (-) wires.
    My eyes are rubbish with colours so I am not sure what the others are.
  14. slepy
    2,085
    321
    It might be but my thought was that it uses only one wire and when you press the horn, it closes the circuit. But i might be wrong. Probably elsawin needed to work it out. Need to finally install mine on laptop.
    Today fitted new scuttle panels. Still water inside the car so decided to change them as they were damaged.
    Also soldered new wires and plug to N75.
    Now need to change the hose that goes from manifold to dv.
    Just not bothered getting under the car when it is pissing outside non stop.
    Is the 710N DV a straight swap? Does it need any adaptation?
  15. Broken Byzan
    13,237
    465
    Horn wire just grounds to operate and dv is a direct replacement
  16. slepy
    2,085
    321
    Thank you :)
  17. slepy
    2,085
    321
    Took the car for a drive after wiring up the N75 valve yesterday.
    The good news is that it runs a lot better. Not that much stuttering as before.
    Now it happens mainly on full throttle but not every time!
    There is still high pitch boost leak sound though.
    You can hear it here 12-15 sec.
    https://www.youtube.com/watch?v=Lkh4UsZxcbQ
    Will fit the new DV to manifold hose and the 710N as soon as I get jubilee clips.
    Bad news is that when I floored it few times my oil light came on so I need to find a ramp to get the oil pump done
    first thing.
    BTW. 330mm steering wheel feels absolutely brilliant!
  18. slepy
    2,085
    321
    Guys, what's the best tool to undo the 2 bolts that hold sump to gearbox. There isnt much space so normal ratchet extension won't do. Is a flexi 1/2" extension any good for that? These bolts were seriously stuck when I checked last time. My 1/4" flexi died quickly on them.
    I would love to try them with impact wrench but no chance to access with it. Want to do it Monday so need to get something good from machine mart before I start.
  19. aragorn
    17,960
    702
    Long allen key perhaps?
    cant remember but quite a few of those bolts in that area have both internal and external hex?
    If its the ring of four bolts that connect the sump to the box, then you can lift the engine slightly, or drop the back of the subframe down to improve access to them.
  20. slepy
    2,085
    321
    In mine it's just a hex bolt. No allen inside. Will get a 1/2" flexi and see if it works. Otherwise will need to drop the subframe :(
  21. slepy
    2,085
    321
  22. Broken Byzan
    13,237
    465
    Does seem cheap. If refurbished could be a bargain
  23. Broken Byzan
    13,237
    465
    I lift engine and use 3/8 on a wobble extension and 16mm socket. I have used a wobble Allen too.
  24. slepy
    2,085
    321
    Well my seats didnt sell on auction although i had 4 guys interested. On the positive side I bought a turbo charger. Genuibe k03 from a4 . It's been stripped down, cleaned, new bearings and new seals. Rebuilt by a qualified turbo tech according to the seller. That's for £89.99 posted! Hope it fits :)
  25. jaymodunn
    jaymodunn Member
    123
    well i bought one so will see, there were a lot of blacks dropping out of not sure what they are thou, everything else looks good.
  26. Broken Byzan
    13,237
    465
    Bought one ? What's dropping from where ?:)
  27. slepy
    2,085
    321
    Yeah. I think its a wrong thread :)
  28. jaymodunn
    jaymodunn Member
    123
    no i meant the turbo listed in the ebay advert..
  29. slepy
    2,085
    321
    The same as I did? Refurbed k03?
  30. jaymodunn
    jaymodunn Member
    123
    yes i think he had 2 for sale, looks good not sure which parts where changed, the black comes off thou, so black hands...
  31. slepy
    2,085
    321
    Hmm sounds fishy. But for 90 quid hard to expect perfect turbo. Just hope it isn't some Chinese ****. Did you have it fitted already?
  32. jaymodunn
    jaymodunn Member
    123
    no i am sending it back due the amount of black bits which i guess is from inside the oil bit but i am not taking a risk as i have bought others off ebay and they didn't have these bits. could cause issues once connected up.
  33. slepy
    2,085
    321
    Will have a look at mine and see if it's the same.
  34. Broken Byzan
    13,237
    465
    Ahh so the paint is coming off. I'd not worry its likely just to make it look pretty
  35. jaymodunn
    jaymodunn Member
    123
    the paint comes off but i think the where the oil goes has carbonized residue which is what falling out, i don't want to take the risk clogging my lines with the **** stuck in there.
    i have to say the seller is a right arse, there is no way i would fit it into my oil supply as most likely contaminate my oil and lines, so take care before you fit.
  36. slepy
    2,085
    321
    I will see if mine is the same. If it is I might be sending it back as well.
  37. slepy
    2,085
    321
    Did the door blades delete today.
    Worked out quite well + saved me a bit of cash.
  38. AlexA4Avant
    AlexA4Avant Active Member
    611
    102
    43
    Sorry what are door blades
  39. Oranoco
    Oranoco Well-Known Member
    3,801
    349
    Rubber trims that sit on the bottom edge of the doors
    slepy likes this.
  40. AlexA4Avant
    611
    102
    43
    O ok thank you gonna spray my ones up when I get a bit of time and paint to match
