TQS progress thread, From STD-Scroll-Eliminator.
Broken Byzan Nov 14, 2009
  1. Broken Byzan
    13,237
    465
    Many things have changed on her, and lazyness on my part.
    I have collected some parts ready to be fitted when funds allow.
    S4 skirts and door trims,
    Votex front and rear skirts.
    RS4 Front brakes..
    The main thing i have changed is the front spring seats to B7 alloy ones as they add 10-15mm to my ride height.I had been struggling with the front being too low to be practical.
    I have pics and will add them when at the proper PC.
    The big news is, my gorgeous wife is sponsoring my car to be mapped. The car is currently all alone at the tuners being done. I have asked for a run before the flashable ECU is fitted out of morbid curiosity to see what the maths provided us with.
    I am then hoping for a run on the flashable ECU for a base figure before the magicians work their magic. I am so excited, but also worried that it won't realise any more power than the pikey mod we currently have running,LOL.
    So as it stands when standard i had 175 BHP and we now await updates.....
  2. Broken Byzan
    13,237
    465
    As an addition, i am thinking about cobbling together a larger TIP like Badger Bill has as gain are to be had there with very little downsides and additional mapping doesn't seem to be necessary to release the power
  3. docurley
    4,070
    85
    Very interesting I will be following your progress.
  4. Broken Byzan
    13,237
    465
    Ok i asked the guys to run her as is to start with just to see and we came up with this..
    Thats not bad for our guesswork tweaks, not as much as the maths would have suggested as the following plot is ATW from when she was bog standard
    Quote "Its not a very smooth curve but not bad considering the ECU is unable to accuratley work out load values because of the maf mod.
    There is obviously something amiss there so mapped correctly even running the same boost there is more power to be had. "
    This is the ride height after the matching spring seats were fitted, not as "slammed" looking but she drives so much better now.
    Before the B6/7 seats were fitted she used to ground out on white lines.
  5. Broken Byzan
    13,237
    465
    Slight update, Flashable ECU fitted and ATW run done. It seems to spool a bit quicker than the TQS ecu did.
    Also a pin added to ECU harness to allow OBD flashing to save time in the future.
    018CJ now puts 134 down ATW
    This one is currently only boosting at std 8 PSi as its originally from a 150 BHP car
    OEM turbo and map did 132.
    thats boosting at 12 psi IIRC
  6. nwmlarge
    nwmlarge flat out
    219
    i am thoroughly confused by that selection of graphs.
    what was the original atw power and what is it now ?
  7. Broken Byzan
    13,237
    465
    131.2 on oem turbo and ecu @ 12 psi base line figure
    134.8 on scroll Outlaw and 018CJ ECU and 8 PSI, so now i have the same power as OEM but at a lower pressure and added bonus of flashable ECU
  8. Lee Goodall
    Lee Goodall Active Member
    2,279
    When you say OEM you mean the 180BHP Quattro map (12 PSI) yeah?
  9. Lee Goodall
    2,279
    At 20+ PSI you should see some good figures then (fingers crossed).
  10. nwmlarge
    nwmlarge flat out
    219
    makes a lot more sense now.
  11. Broken Byzan
    13,237
    465
    yes mate
  12. Lee Goodall
    2,279
    So you've gained 30BHP from the hybrid turbo alone (150BHP - 180BHP ish).
    How is that working if the boost is calculated from the MAF? or is that with the 3" MAF fitted too?
  13. Broken Byzan
    13,237
    465
    yes that's right mate
  14. Lee Goodall
    2,279
    I see.. nice work!
  15. Broken Byzan
    13,237
    465
    yeah fueling wasn't perfect , but is on the safe side of wrong so that's good. Timing is being left to the ECU currently, so again safe, but not perfect. Over all i am happy with that.
    I am just waiting for the next installment now......
  16. aragorn
    18,159
    766
    The boost figures you mention above cant be right.
    The ECU bases the boost pressure on the MAF, and the MAF has changed... As a result both the 558DA and 018CJ will be running more boost than they're mapped for, simply because of the scaled maf.
  17. Lee Goodall
    2,279
    ..but the OEM figure is on the smaller OEM MAF isn't it? That's what I presumed anyway. The other figures do show increased boost.
    EDIT- show increased power sorry not boost but there's obviously increased airflow.
  18. aragorn
    18,159
    766
    His original 130hp ATW figure was on the old maf at 12psi, sure.
    But he said the run on the 018CJ ecu was at 8psi, but it wont have been due to the 3" MAF.
  19. Lee Goodall
    2,279
    I think he means the ECU is mapped to produce 8PSI (used as a reference).
  20. aragorn
    18,159
    766
    That suggests he thinks he made 134.8 at 8psi...
  21. Lee Goodall
    2,279
    Oh yeah.. I see what you mean.
    Maybe Tuneside could confirm what actual boost is being made?
  22. Broken Byzan
    13,237
    465
    Ok ok ok, i have been told off, The boost pressures are what the ECU is seeing, due to the scaled MAF. In reality they are 3 -4 PSI better that that. Sorry for misleading
    so 15 on 558DA and 11-12 on 018CJ OK ?
  23. Lee Goodall
    2,279
    Kev-->:asskicking:<--Mark
  24. aragorn
    18,159
    766
    :ninja: Me?!
  25. <tuffty/>
    21,016
    3,780
    Good work mate... looks like yours will be mapped up and done before mine!! LOL
  26. Broken Byzan
    13,237
    465
    Maybe, Depends on many factors.....:tapedshut::tapedshut::tapedshut:
  27. <tuffty/>
    21,016
    3,780
    It will all be fine mate... what ever happens we will work it out one way or other :thumbsup:
  28. S3 Rav
    S3 Rav Well-Known Member
    2,824
    30
    So you did go to tuneside in the end then.
  29. Broken Byzan
    13,237
    465
    Yep ^^
    Mid tweakage plot.
    AFR was running at around 13:1 before and i am hoping for an AFR of 12:1 ish @ WOT
    I think that's right i don't have my emailed figures here
  30. aragorn
    18,159
    766
    13:1 on the original setup.
    11:1 just now but aiming for 12:1 once the maps completed i'd expect.
  31. Broken Byzan
    13,237
    465
    i knew you would be along.LOL
  32. <tuffty/>
    21,016
    3,780
    No AFR or boost plot to with that graph mate? would be interested to see how AFR is affecting the power in this case... if you say its rich higher up that would explain the graph somewhat but would be nice to see how AFR is doing in relation to the curve :)
  33. Broken Byzan
    13,237
    465
    I am hoping for this sometime today
  34. Lee Goodall
    2,279
    So that's about 215 BHP so far.
    Looking forward to the next update.
  35. docurley
    4,070
    85
    So you now have a new ECU which can be flashed and your car's currently being custom mapped via the OBD port with one extra wire to allow this is that correct sofar........ oh and you have around 215bhp with initial mapping.
    So please tell what sort of money will they be looking for to do another custom map?
  36. Broken Byzan
    13,237
    465
    Hard to be sure exact figure @ FW at the mo.
    But yeah more or less mate.
    Yours is flashable anyway so you're good to go
    Its around 250 assuming 25% losses atm hoping for slightly more without pushing it too much as it's currently doing 1.5 bar @ max power and 1.2 to redline
  37. Lee Goodall
    2,279
    What's 250 mate? I'm confused (I know.. doesn't take much lol)
    Edit - ha ha I see minus 25%!! Got it.
  38. Lee Goodall
    2,279
    I was using the WHP / 0.85 = BHP.
    Your calculation would be WHP / 0.75 = BHP then.
  39. Broken Byzan
    13,237
    465
    you might be right mate, i was going on what kev said and 25 % ish
  40. Lee Goodall
    2,279
    Sure there's a difference between loses on FW and 4WD too anyway.
