TQS progress thread, From STD-Scroll-Eliminator.
Broken Byzan Nov 14, 2009
  1. Broken Byzan
    13,237
    466
    The std S4 exhaust splits to a "Y" so i cut off that section.
    The back section will bolt directly on no worries, and i recon any decent exhaust place could stick a Y in the dual section and reduce it to suit the TQS for a few quid.
    When this expires it's probably what i will do myself tbh. I wanted to do it cheaply first, and seeing i can weld mild steel with my dodgy welder i thought this would suffice
  2. jamie226bhp
    jamie226bhp Member
    468
    looking at those ebay one's or the 3" that 034 do for about $800 just need the exchange rate to get better
  3. aragorn
    18,606
    871
    tbh, if your going to spend $800, then just take the car to an exhaust place and get a custom system made up...
  4. jamie226bhp
    jamie226bhp Member
    468
    Wasn't sure what they would be like for flow etc as you always hear that an exhaust can make or break all your other mods, my mate can make me one but he's got to buy all the bends and straights and weld them together and i wasn't sure how all the welding would afect the flow charactaristics of the exhaust
  5. aragorn
    18,606
    871
    well even with a bit of welding, a 3" system is going to be a damn sight better than the stock 2.25" if your winding up the powar....
  6. jamie226bhp
    jamie226bhp Member
    468
    what 4 bar fpr did you use or are the AJL's already 4 bar
  7. aragorn
    18,606
    871
    They already have it.
  8. Broken Byzan
    13,237
    466
    I only made a point of mentioning as some tuners use the 3 bar and the injectors are rated at 3bar.
    At 4 bar the increase in flow is 15% from the rated value at 3 BAR.
  9. Broken Byzan
    13,237
    466
    EDIT by the maths Aragorn worked out the other day relating to fueling, if i stick my 340's in and run it on a 3bar FPR and the 72mm VR6 MAF, my fueling will only be 1.5% out.....
    If this works out, i will blag the equation from him and post it somewhere
  10. Broken Byzan
    13,237
    466
  11. Lee Goodall
    Lee Goodall Active Member
    2,279
  12. jcb
    jcb Active Member
    4,132
    13
    what does "MWU" stand for?
    answers on a post card........
  13. Lee Goodall
    2,279
    Not sure about the 'U' but the other bits easy.
    Really like the plates.. look very smart.
  14. Geeman
    Geeman Low Life
    1,318
    Mark something-or-other...
    Had the chance of buying a '95 Audi Coupe with the plate A4 UHT the other week, but let it pass by.
  15. ALPINE
    3,093
    The U in marks numberplate is for UNTOUCHABLE!!! god thought you lot knew everything!! :p lol
  16. Broken Byzan
    13,237
    466
    It stands for, it was cheap and as close as i could get when i bought it,lol
    Mark White But if you sound it out its M Double U, kinda works. MAW ( my initials) seem to be dead expensive
  17. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    it was nice when you had his and hers plates for the Audis
  18. R-Tech-Nick
    R-Tech-Nick Active Member
    150
    51
    Hello m8,
    With your map it will be a one off map..:cool: wrote in front of your eyes, and you can even have a say on mapping as we are doing it.
    In theory you can just use vagcom and vagtacho to get the 018CJ up and running, I have a guy in Wales who can lend you a hand when it come to coding the ecu and immo he has both tools to do the job, It can easy be patched as an open immo by taking the E2 (serial eeprom) off and changing a few of the hex values, the best way to do it is with the immo inplace, best safe then sorry imo.
    Nick
  19. Broken Byzan
    13,237
    466
    Thanks, i think its locked to the old car somehow as i can adapt it to the dash and it all looks good but still kicks in the immo I have vagcom/Tacho.
    I have had it running.I had to "mod" the immo to allow it for testing but am looking forward to maybe making the fix more permenant.
    I can drive to meet your guy if necc if you think it will help so we have some base adaptions stored prior to mapping
    Sorry for the hijack OP.
    Nick if there is anything to add can we continue convo on my build thread
    http://www.audi-sport.net/vb/showthread.php?82912-Budget-Hybrid-Turbo-tuning-on-my-TQS/page3
  20. aragorn
    18,606
    871
    Ok, so the parts are fitted, so i persuaded mark to try some redneck tuning!
    The AEB/AJL ECU doesnt have any boost pressure monitoring, it bases everything on the Airflow reading alone. Changing the AFM for a larger unit, means that for a given airflow, the velocity thru the sensor is lower, so the voltage outputted is lower and the ECU "sees" less air, as a result, the ECU will push up the duty cycle on the N75 to attempt to achieve what it thinks is the correct amount of air. Obviously the big problem then is having the fuel to match, so i did some maths to work it out.
    First some research:
    Google provided the following data:
    5v on S4 AFM (73mm ID) is 330g/s
    5v on RS4 AFM (83mm ID) is 430g/s
    430/330 = 30% difference in Airflow
    73mm ID = 41.8cm^2 (3.14 * (7.3/2)^2)
    83mm ID = 54.1cm^2 (3.14 * (8.3/2)^2)
    54.1/41.8 = 29.4% difference in Area
    This shows that peak peak airflow is directly related to area.
    Apply these findings to Marks engine:
    New AFM = 73mm ID = 41.8cm^2
    Old AFM = 62mm ID = 30.2cm^2
    That gives us
    41.8/30.2 = 38.4% difference in Area
    So for any given airflow figure the ECU is seeing, the engines actually swallowing 38.4% more air...
    This is shown my looking at the adaption values, after a few short drives with the 3" AFM fitted the ECU was showing adaption fault codes and lambda multiplicative adaption is jammed at 25%...
    Next we look at fuel:
    Stock AEB injectors are 210cc/min@3bar, however the AEB runs a 4 bar pressure regulator, giving an actual output of 240cc/min (3->4 bar gives +15%)
    Mark has a set of C20LET injectors which are rated at 340cc/min at 3bar.
    Some more maths:
    340/240 = 41.6%, So the LET injectors at 3bar are flowing 41.6% more fuel than the AEB injectors at 4bar.
    Looks close enough for lambda correction to handle, so mark swapped in the C20LET injectors, and fitted a 3 bar fuel regulator inplace of the 4 bar item.
    I'll leave mark to post his findings, as he's driven the car, but suffice it to say lambda adaption is now down to a friendly 3%.
  21. Broken Byzan
    13,237
    466
    As Kev says, we did some measuring and maths and applied it to the car and this has got a car that feels much more responsive to drive and seems to have more go.
    I have seen a spike of 1.2 bar, but more commonly 1.1, holding 1.0bar till over 5k revs, but by then i was watching where i was going.
    I am hoping to log MAF values later as according to the maths above we apply the fomula vagcom reading *1.38 / 0.8 = bhp ish, give or take. It will give an idea from what we have seen so far including the RR plot i had pre any mods.
  22. Broken Byzan
    13,237
    466
    Ooo to add i also reset the DIS Av MPG counter, so while its adapting etc i am currently showing on DIS 25mpg and climbing, despite my "testing" of the car/boost etc.
    When i log i will log timing corrections and Maf values for comparison
  23. Lee Goodall
    2,279
    Pair o pikeys
  24. aragorn
    18,606
    871
    Well it worked didnt it? Free remap :)
  25. Broken Byzan
    13,237
    466
    Jealous much !!!! :icon_thumright:
  26. Lee Goodall
    2,279
    Yeah.. very impressive really. Sure Mark will be wanting more boost/fuel ASAP though lol
  27. Lee Goodall
    2,279
    :noway: lol :icon_thumright:
  28. Broken Byzan
    13,237
    466
  29. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    All this is very good to know.
  30. Broken Byzan
    13,237
    466
  31. Broken Byzan
    13,237
    466
    Thats the point of us putting it here Ian.More info on the ECU shortly too i hope
  32. aragorn
    18,606
    871
    peak of 153g/s means the actual airflow was around 210g/s, which is around 262hp...
    Does it feel faster than an S4? :p
  33. ian52
    1,199
    So would this work for a t28 as well within reason?
  34. Broken Byzan
    13,237
    466
    The maths can be applied to anything mate, within reason obv
  35. ian52
    1,199
    Are you just running the standard ecu at the moment and it works out with the airflow etc to give you 1.1 bar? How does it feel now? Would be good if you are seeing about 260bhp.
  36. Broken Byzan
    13,237
    466
    Ian, yes it's the std ECU atm. In communication to try and get the other ECU unlocked to allow adaptions to the IMMO properly.
    The car feels quite quick now, hard to say how much it feels like as my last car was 200kg lighter with only 250.
    i guess i need to have a run on a rolling road somewhere to see what she is doing
  37. aragorn
    18,606
    871
    If the stock ECU was already remapped to say 200hp, then i would imagine this mod would give you around 280.
    The problem is you cant adjust the ignition timing, so i dunno how much the ecu would like pushing 280hp's worth of power on the timing for 200.
    I guess marks is managing it with a similar gain though.
  38. badger5
    9,599
    2,060
    frigged fuel
    frigged maf/n75
    ignition timing ok?
  39. Broken Byzan
    13,237
    466
  40. Broken Byzan
    13,237
    466
    Whats wrong with the fueling?
    N75 duty not showing and MAF is in a larger housing so will read lower
    I have seen std cars pull almost as much timing, so whats wrong there
    I appreciate your comments, but you could at least quantify them a little
