TQS progress thread, From STD-Scroll-Eliminator.
Broken Byzan Nov 14, 2009
  1. Broken Byzan
    13,237
    466
    never see 400 in a million years, US hp maybe, but not good old fashioned UK genuine BHP.
    Id be expecting 320 ish with 360 Ft lbs and solid low spool to make for a quickish car.
    I just need a clutch that can handle it, mine slips on NLS
  2. badger5
    9,603
    2,061
    VVT, active when -4 (22 deg)
  3. Broken Byzan
    13,237
    466
    That proves what I felt then, the car is deffo livlier when it's active. I'd guess it's also what's affecting my part throttle/ low rev running or stumbling, maybe aiding the car in poping back due to overlap
  4. gmx
    gmx Member
    148
    Are you using VVT with standard AJL cams?
  5. aragorn
    18,612
    872
    yep he is.
  6. badger5
    9,603
    2,061
    simple to check by resetting the vvt, on cold start maps to nothing to see how thats effecting things on cold cycle vs warmed up vvt mode
  7. Broken Byzan
    13,237
    466
    yeah what he said ^^
  8. Gops
    3,198
    666
    Do those adaptors fit yet mark?
  9. Broken Byzan
    13,237
    466
    TBH bud, I've not tried them, I see no reason why not.
    I need to find the cash to order the valve spring,retainers and a cam then try and blag a ramp for a few days @ Bills. But Bill is flat out ( good for business) and I'm skint,lol
    The biggest issue with mine atm is the 1 litre a week of oil she is drinking, It's almost a 2 stroke....
    Also I got ripped off on a VVT that was supposed to be genuine, but it wasn't and i have had to stump up an additional fee for customs and return postage to get this sorted that I wasn't expecting.
    At this rate, I'll be driving my daughters 1.1 Clio so I have a reliable car..........GULP
  10. Broken Byzan
    13,237
    466
    A few bits to fix the head.
    Supertech valves and seals
    Tubular ex manifold, Devills own WMI kit and a wellycooler
    Hopefully this should stop it bottle necking and excess heat being generated
    Inlet cam specs VVT safe apparently
    Side by side with a std 1.8t cam
    This is the "matching" exhaust cam as recommended by CAT, I have to say the spec is so similar to the 3665 designated cam anyway, i'd bet they are the actual same part, but designated differently depending on the inlet pairing
    Exhaust cam side by side
  11. Broken Byzan
    13,237
    466
    I am attempting to do all this in 2 weeks provided all goes well with the baby due tomorrow. That should stop my car being a damned 2 stroke and a a heat pump so Bill can work his magic on it for me :beerchug: and install the multi maps on it, One to be banzai WMI dependent, and then one as good as it can be without WMI, but will prob run it for cooling. Then an actuator only jobbie.
  12. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    Looks sweet. Congrats ahead of your childs birth.
    How agressive are those cams? Allways wondered if you can mild cam a 1.8t without a remap
  13. Broken Byzan
    13,237
    466
    I asked for OEM idling and not massive overlap because it seem the 1.8t isn't happy with huge overlaps. I'm not sure on gains yet, and my car will be mapped to take account of them, even if it's just a slightly higher rev limit IIRC it currently stands at 7800. I'm hoping the extra flow will allow power to be made easier and then stop the damn thing turning boosts and timing into heat,lol
  14. Broken Byzan
    13,237
    466
    I've done some tinkering while waiitng for parts
    Tubular manifold tweaked and test fitted
    Bill got in there with his die grinder
    Some more pics on his FB
    ARP bolts fitted to everything I can feasibly do
    Lucky escape here
    Waiting for an ARP crank bolt and an IE top pulley and bolt to come from IE to properly get into it and assemble the head properly, then we can look at timing the cams up properly using Bills special tool for cam timing from IE, curious to see how much the std marks are out in regards to where they end up
  15. Broken Byzan
    13,237
    466
    A few logs from today. WMI on but only water and still on actuator only, so 1 bar boost AFR at top of 12.3 ish. She is now fitted with an EGT probe so will ask Nicely to get it enabled and we can log that too
    MAF scaling is STD so that can be relied upon in the /.8 for BHP ( 327 on actuator). But load is maxed out :sly:
    Code:
      [TABLE]
    [TR]
    [TD="align: right"]28[/TD]
    [TD]June[/TD]
    [TD="width: 80, align: right"]2013[/TD]
    [TD="class: xl63, width: 108, align: right"]18:31:18[/TD]
    [TD="width: 94"][/TD]
    [TD="width: 64"][/TD]
    [TD="width: 93"][/TD]
    [TD="width: 120"][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD="colspan: 3"]1.8L R4/5VT     G03 0004[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Group A:[/TD]
    [TD]'002[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'003[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'020[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Engine RPM[/TD]
    [TD]Engine Load[/TD]
    [TD]Ave. Inj. Period[/TD]
    [TD]Air Mass Flow[/TD]
    [TD][/TD]
    [TD]Engine RPM[/TD]
    [TD]Throttle Opening[/TD]
    [TD="colspan: 2"]Ign. Timing[/TD]
    [TD]Cyl #1[/TD]
    [TD]Cyl #2[/TD]
    [TD]Cyl #3[/TD]
    [TD]Cyl #4[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD]%[/TD]
    [TD] ms[/TD]
    [TD] g/s[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD]%[/TD]
    [TD] °ATDC[/TD]
    [TD]STAMP[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]3.8[/TD]
    [TD="class: xl64, align: right"]2600[/TD]
    [TD="class: xl64, align: right"]34.6[/TD]
    [TD="class: xl64, align: right"]2.04[/TD]
    [TD="class: xl64, align: right"]11.06[/TD]
    [TD="class: xl64, align: right"]4.31[/TD]
    [TD="class: xl64, align: right"]3800[/TD]
    [TD="class: xl64, align: right"]14.44[/TD]
    [TD="class: xl64, align: right"]8.2[/TD]
    [TD="class: xl64, align: right"]14.3[/TD]
    [TD="class: xl64, align: right"]4.71[/TD]
    [TD="class: xl64, align: right"]0[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]5.11[/TD]
    [TD="class: xl64, align: right"]3680[/TD]
    [TD="class: xl64, align: right"]46.6[/TD]
    [TD="class: xl64, align: right"]3.74[/TD]
    [TD="class: xl64, align: right"]33.47[/TD]
    [TD="class: xl64, align: right"]5.61[/TD]
    [TD="class: xl64, align: right"]34.89[/TD]
    [TD="class: xl64, align: right"]17.6[/TD]
    [TD="class: xl64, align: right"]33[/TD]
    [TD="class: xl64, align: right"]6.01[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]6.42[/TD]
    [TD="class: xl64, align: right"]3760[/TD]
    [TD="class: xl64, align: right"]60.9[/TD]
    [TD="class: xl64, align: right"]4.42[/TD]
    [TD="class: xl64, align: right"]44.78[/TD]
    [TD="class: xl64, align: right"]6.92[/TD]
    [TD="class: xl64, align: right"]45.06[/TD]
    [TD="class: xl64, align: right"]20.8[/TD]
    [TD="class: xl64, align: right"]32.3[/TD]
    [TD="class: xl64, align: right"]7.32[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]7.72[/TD]
    [TD="class: xl64, align: right"]3840[/TD]
    [TD="class: xl64, align: right"]75.2[/TD]
    [TD="class: xl64, align: right"]5.1[/TD]
    [TD="class: xl64, align: right"]56.89[/TD]
    [TD="class: xl64, align: right"]8.14[/TD]
    [TD="class: xl64, align: right"]3880[/TD]
    [TD="class: xl64, align: right"]52.72[/TD]
    [TD="class: xl64, align: right"]23.1[/TD]
    [TD="class: xl64, align: right"]30[/TD]
    [TD="class: xl64, align: right"]8.63[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]9.03[/TD]
    [TD="class: xl64, align: right"]4040[/TD]
    [TD="class: xl64, align: right"]66.2[/TD]
    [TD="class: xl64, align: right"]4.76[/TD]
    [TD="class: xl64, align: right"]49.75[/TD]
    [TD="class: xl64, align: right"]9.43[/TD]
    [TD="class: xl64, align: right"]49.14[/TD]
    [TD="class: xl64, align: right"]22[/TD]
    [TD="class: xl64, align: right"]31.5[/TD]
    [TD="class: xl64, align: right"]9.83[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]10.25[/TD]
    [TD="class: xl64, align: right"]4120[/TD]
    [TD="class: xl64, align: right"]54.9[/TD]
    [TD="class: xl64, align: right"]43.64[/TD]
    [TD="class: xl64, align: right"]10.74[/TD]
    [TD="class: xl64, align: right"]43.58[/TD]
    [TD="class: xl64, align: right"]20[/TD]
    [TD="class: xl64, align: right"]11.14[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]11.65[/TD]
    [TD="class: xl64, align: right"]4200[/TD]
    [TD="class: xl64, align: right"]51.9[/TD]
    [TD="class: xl64, align: right"]40.61[/TD]
    [TD="class: xl64, align: right"]12.05[/TD]
    [TD="class: xl64, align: right"]19.2[/TD]
    [TD="class: xl64, align: right"]33.8[/TD]
    [TD="class: xl64, align: right"]12.45[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]12.85[/TD]
    [TD="class: xl64, align: right"]43.6[/TD]
    [TD="class: xl64, align: right"]3.4[/TD]
    [TD="class: xl64, align: right"]35.08[/TD]
    [TD="class: xl64, align: right"]13.25[/TD]
    [TD="class: xl64, align: right"]35.31[/TD]
    [TD="class: xl64, align: right"]35.3[/TD]
    [TD="class: xl64, align: right"]13.65[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]14.07[/TD]
    [TD="class: xl64, align: right"]13.5[/TD]
    [TD="class: xl64, align: right"]1.36[/TD]
    [TD="class: xl64, align: right"]12.83[/TD]
    [TD="class: xl64, align: right"]14.57[/TD]
    [TD="class: xl64, align: right"]3240[/TD]
    [TD="class: xl64, align: right"]8.94[/TD]
    [TD="class: xl64, align: right"]5.5[/TD]
    [TD="class: xl64, align: right"]2.3[/TD]
    [TD="class: xl64, align: right"]14.95[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]2840[/TD]
    [TD="class: xl64, align: right"]36.1[/TD]
    [TD="class: xl64, align: right"]2.72[/TD]
    [TD="class: xl64, align: right"]18.5[/TD]
    [TD="class: xl64, align: right"]55.29[/TD]
    [TD="class: xl64, align: right"]2720[/TD]
    [TD="class: xl64, align: right"]7.8[/TD]
    [TD="class: xl64, align: right"]54.4[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]56.11[/TD]
    [TD="class: xl64, align: right"]33.1[/TD]
    [TD="class: xl64, align: right"]24.81[/TD]
    [TD="class: xl64, align: right"]56.51[/TD]
    [TD="class: xl64, align: right"]4000[/TD]
    [TD="class: xl64, align: right"]87.06[/TD]
    [TD="class: xl64, align: right"]94.9[/TD]
    [TD="class: xl64, align: right"]27.8[/TD]
    [TD="class: xl64, align: right"]55.69[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]57.41[/TD]
    [TD="class: xl64, align: right"]4360[/TD]
    [TD="class: xl64, align: right"]191.7[/TD]
    [TD="class: xl64, align: right"]13.26[/TD]
    [TD="class: xl64, align: right"]164.33[/TD]
    [TD="class: xl64, align: right"]57.81[/TD]
    [TD="class: xl64, align: right"]4560[/TD]
    [TD="class: xl64, align: right"]174.03[/TD]
    [TD="class: xl64, align: right"]100[/TD]
    [TD="class: xl64, align: right"]15.8[/TD]
    [TD="class: xl64, align: right"]56.91[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]58.62[/TD]
    [TD="class: xl64, align: right"]4880[/TD]
    [TD="class: xl64, align: right"]13.6[/TD]
    [TD="class: xl64, align: right"]183.39[/TD]
    [TD="class: xl64, align: right"]59.02[/TD]
    [TD="class: xl64, align: right"]5040[/TD]
    [TD="class: xl64, align: right"]191[/TD]
    [TD="class: xl64, align: right"]10.5[/TD]
    [TD="class: xl64, align: right"]58.22[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]59.82[/TD]
    [TD="class: xl64, align: right"]5360[/TD]
    [TD="class: xl64, align: right"]14.62[/TD]
    [TD="class: xl64, align: right"]209.86[/TD]
    [TD="class: xl64, align: right"]60.22[/TD]
    [TD="class: xl64, align: right"]5520[/TD]
    [TD="class: xl64, align: right"]222.97[/TD]
    [TD="class: xl64, align: right"]12[/TD]
    [TD="class: xl64, align: right"]59.42[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]61.04[/TD]
    [TD="class: xl64, align: right"]5840[/TD]
    [TD="class: xl64, align: right"]15.64[/TD]
    [TD="class: xl64, align: right"]231.97[/TD]
    [TD="class: xl64, align: right"]61.44[/TD]
    [TD="class: xl64, align: right"]6000[/TD]
    [TD="class: xl64, align: right"]238.61[/TD]
    [TD="class: xl64, align: right"]60.62[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]62.33[/TD]
    [TD="class: xl64, align: right"]6320[/TD]
    [TD="class: xl64, align: right"]15.3[/TD]
    [TD="class: xl64, align: right"]250.69[/TD]
    [TD="class: xl64, align: right"]62.75[/TD]
    [TD="class: xl64, align: right"]6440[/TD]
    [TD="class: xl64, align: right"]253.14[/TD]
    [TD="class: xl64, align: right"]61.84[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]63.65[/TD]
    [TD="class: xl64, align: right"]6760[/TD]
    [TD="class: xl64, align: right"]257.56[/TD]
    [TD="class: xl64, align: right"]64.05[/TD]
    [TD="class: xl64, align: right"]6840[/TD]
    [TD="class: xl64, align: right"]259.44[/TD]
    [TD="class: xl64, align: right"]63.15[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]64.86[/TD]
    [TD="class: xl64, align: right"]7080[/TD]
    [TD="class: xl64, align: right"]262.56[/TD]
    [TD="class: xl64, align: right"]65.26[/TD]
    [TD="class: xl64, align: right"]7200[/TD]
    [TD="class: xl64, align: right"]262.06[/TD]
    [TD="class: xl64, align: right"]64.45[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]66.06[/TD]
    [TD="class: xl64, align: right"]7440[/TD]
    [TD="class: xl64, align: right"]185.7[/TD]
    [TD="class: xl64, align: right"]14.28[/TD]
    [TD="class: xl64, align: right"]66.46[/TD]
    [TD="class: xl64, align: right"]7120[/TD]
    [TD="class: xl64, align: right"]9.8[/TD]
    [TD="class: xl64, align: right"]18.8[/TD]
    [TD="class: xl64, align: right"]65.66[/TD]
    [/TR]
    [/TABLE]
    Code:
      [TABLE]
    [TR]
    [TD="width: 64"]June[/TD]
    [TD="width: 64, align: right"]2013[/TD]
    [TD="class: xl63, width: 64, align: right"]18:39:09[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Group A:[/TD]
    [TD]'004[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'003[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'020[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Engine RPM[/TD]
    [TD]System Voltage[/TD]
    [TD]Coolant Temp.[/TD]
    [TD="colspan: 2"]Intake Air Temp[/TD]
    [TD]Engine RPM[/TD]
    [TD]Cyl #1[/TD]
    [TD]Cyl #2[/TD]
    [TD]Cyl #3[/TD]
    [TD]Cyl #4[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]TIME[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] V[/TD]
    [TD]°C[/TD]
    [TD]°C[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD]%[/TD]
    [TD] °BTDC[/TD]
    [TD]STAMP[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [TD] CF[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]497.96[/TD]
    [TD="class: xl64, align: right"]2120[/TD]
    [TD="class: xl64, align: right"]13.58[/TD]
    [TD="class: xl64, align: right"]81[/TD]
    [TD="class: xl64, align: right"]23[/TD]
    [TD="class: xl64, align: right"]498.36[/TD]
    [TD="class: xl64, align: right"]2080[/TD]
    [TD="class: xl64, align: right"]5.03[/TD]
    [TD="class: xl64, align: right"]3.5[/TD]
    [TD="class: xl64, align: right"]497.57[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]499.28[/TD]
    [TD="class: xl64, align: right"]2040[/TD]
    [TD="class: xl64, align: right"]13.72[/TD]
    [TD="class: xl64, align: right"]499.69[/TD]
    [TD="class: xl64, align: right"]4.94[/TD]
    [TD="class: xl64, align: right"]1.5[/TD]
    [TD="class: xl64, align: right"]498.78[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]500.59[/TD]
    [TD="class: xl64, align: right"]501.1[/TD]
    [TD="class: xl64, align: right"]2160[/TD]
    [TD="class: xl64, align: right"]43.97[/TD]
    [TD="class: xl64, align: right"]12.8[/TD]
    [TD="class: xl64, align: right"]500.19[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]501.9[/TD]
    [TD="class: xl64, align: right"]2280[/TD]
    [TD="class: xl64, align: right"]13.86[/TD]
    [TD="class: xl64, align: right"]21[/TD]
    [TD="class: xl64, align: right"]502.3[/TD]
    [TD="class: xl64, align: right"]2360[/TD]
    [TD="class: xl64, align: right"]51.08[/TD]
    [TD="class: xl64, align: right"]95.3[/TD]
    [TD="class: xl64, align: right"]501.5[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]503.1[/TD]
    [TD="class: xl64, align: right"]2480[/TD]
    [TD="class: xl64, align: right"]503.51[/TD]
    [TD="class: xl64, align: right"]2560[/TD]
    [TD="class: xl64, align: right"]65.11[/TD]
    [TD="class: xl64, align: right"]96.1[/TD]
    [TD="class: xl64, align: right"]502.7[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]504.41[/TD]
    [TD="class: xl64, align: right"]2760[/TD]
    [TD="class: xl64, align: right"]13.79[/TD]
    [TD="class: xl64, align: right"]504.91[/TD]
    [TD="class: xl64, align: right"]2880[/TD]
    [TD="class: xl64, align: right"]91.83[/TD]
    [TD="class: xl64, align: right"]98.8[/TD]
    [TD="class: xl64, align: right"]504.01[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]505.72[/TD]
    [TD="class: xl64, align: right"]3080[/TD]
    [TD="class: xl64, align: right"]19[/TD]
    [TD="class: xl64, align: right"]506.12[/TD]
    [TD="class: xl64, align: right"]3200[/TD]
    [TD="class: xl64, align: right"]102.97[/TD]
    [TD="class: xl64, align: right"]505.32[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]506.92[/TD]
    [TD="class: xl64, align: right"]3400[/TD]
    [TD="class: xl64, align: right"]18[/TD]
    [TD="class: xl64, align: right"]507.34[/TD]
    [TD="class: xl64, align: right"]3520[/TD]
    [TD="class: xl64, align: right"]114.42[/TD]
    [TD="class: xl64, align: right"]506.52[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]508.14[/TD]
    [TD="class: xl64, align: right"]508.54[/TD]
    [TD="class: xl64, align: right"]3920[/TD]
    [TD="class: xl64, align: right"]136.92[/TD]
    [TD="class: xl64, align: right"]507.74[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]509.34[/TD]
    [TD="class: xl64, align: right"]4080[/TD]
    [TD="class: xl64, align: right"]509.74[/TD]
    [TD="class: xl64, align: right"]4240[/TD]
    [TD="class: xl64, align: right"]153.78[/TD]
    [TD="class: xl64, align: right"]508.94[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]510.65[/TD]
    [TD="class: xl64, align: right"]4480[/TD]
    [TD="class: xl64, align: right"]511.05[/TD]
    [TD="class: xl64, align: right"]4520[/TD]
    [TD="class: xl64, align: right"]163.69[/TD]
    [TD="class: xl64, align: right"]99.6[/TD]
    [TD="class: xl64, align: right"]16.5[/TD]
    [TD="class: xl64, align: right"]510.15[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]511.86[/TD]
    [TD="class: xl64, align: right"]4760[/TD]
    [TD="class: xl64, align: right"]82[/TD]
    [TD="class: xl64, align: right"]512.36[/TD]
    [TD="class: xl64, align: right"]183.67[/TD]
    [TD="class: xl64, align: right"]511.45[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]513.16[/TD]
    [TD="class: xl64, align: right"]13.51[/TD]
    [TD="class: xl64, align: right"]513.56[/TD]
    [TD="class: xl64, align: right"]5080[/TD]
    [TD="class: xl64, align: right"]193.33[/TD]
    [TD="class: xl64, align: right"]512.76[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]514.38[/TD]
    [TD="class: xl64, align: right"]5200[/TD]
    [TD="class: xl64, align: right"]13.44[/TD]
    [TD="class: xl64, align: right"]514.87[/TD]
    [TD="class: xl64, align: right"]5320[/TD]
    [TD="class: xl64, align: right"]203.44[/TD]
    [TD="class: xl64, align: right"]11.3[/TD]
    [TD="class: xl64, align: right"]513.98[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]515.67[/TD]
    [TD="class: xl64, align: right"]5480[/TD]
    [TD="class: xl64, align: right"]516.09[/TD]
    [TD="class: xl64, align: right"]5560[/TD]
    [TD="class: xl64, align: right"]220.5[/TD]
    [TD="class: xl64, align: right"]515.27[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]516.89[/TD]
    [TD="class: xl64, align: right"]5680[/TD]
    [TD="class: xl64, align: right"]517.29[/TD]
    [TD="class: xl64, align: right"]5760[/TD]
    [TD="class: xl64, align: right"]229.89[/TD]
    [TD="class: xl64, align: right"]516.49[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]518.2[/TD]
    [TD="class: xl64, align: right"]5920[/TD]
    [TD="class: xl64, align: right"]24[/TD]
    [TD="class: xl64, align: right"]518.6[/TD]
    [TD="class: xl64, align: right"]237.86[/TD]
    [TD="class: xl64, align: right"]517.69[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]519.4[/TD]
    [TD="class: xl64, align: right"]6120[/TD]
    [TD="class: xl64, align: right"]13.37[/TD]
    [TD="class: xl64, align: right"]519.8[/TD]
    [TD="class: xl64, align: right"]6160[/TD]
    [TD="class: xl64, align: right"]243.11[/TD]
    [TD="class: xl64, align: right"]519[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]520.62[/TD]
    [TD="class: xl64, align: right"]6280[/TD]
    [TD="class: xl64, align: right"]521.11[/TD]
    [TD="class: xl64, align: right"]6400[/TD]
    [TD="class: xl64, align: right"]251.97[/TD]
    [TD="class: xl64, align: right"]520.2[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]521.91[/TD]
    [TD="class: xl64, align: right"]6480[/TD]
    [TD="class: xl64, align: right"]25[/TD]
    [TD="class: xl64, align: right"]522.31[/TD]
    [TD="class: xl64, align: right"]6560[/TD]
    [TD="class: xl64, align: right"]521.51[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]523.22[/TD]
    [TD="class: xl64, align: right"]6680[/TD]
    [TD="class: xl64, align: right"]26[/TD]
    [TD="class: xl64, align: right"]523.62[/TD]
    [TD="class: xl64, align: right"]6720[/TD]
    [TD="class: xl64, align: right"]259.56[/TD]
    [TD="class: xl64, align: right"]522.73[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]524.44[/TD]
    [TD="class: xl64, align: right"]524.84[/TD]
    [TD="class: xl64, align: right"]6880[/TD]
    [TD="class: xl64, align: right"]262.28[/TD]
    [TD="class: xl64, align: right"]524.02[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]525.64[/TD]
    [TD="class: xl64, align: right"]6960[/TD]
    [TD="class: xl64, align: right"]526.13[/TD]
    [TD="class: xl64, align: right"]7000[/TD]
    [TD="class: xl64, align: right"]265.92[/TD]
    [TD="class: xl64, align: right"]525.24[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]526.95[/TD]
    [TD="class: xl64, align: right"]7040[/TD]
    [TD="class: xl64, align: right"]27[/TD]
    [TD="class: xl64, align: right"]527.35[/TD]
    [TD="class: xl64, align: right"]526.53[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]528.15[/TD]
    [TD="class: xl64, align: right"]528.55[/TD]
    [TD="class: xl64, align: right"]7240[/TD]
    [TD="class: xl64, align: right"]266.61[/TD]
    [TD="class: xl64, align: right"]527.75[/TD]
    [/TR]
    [TR]
    [TD="class: xl64, align: right"]529.35[/TD]
    [TD="class: xl64, align: right"]83[/TD]
    [TD="class: xl64, align: right"]529.77[/TD]
    [TD="class: xl64, align: right"]21.92[/TD]
    [TD="class: xl64, align: right"]8.6[/TD]
    [TD="class: xl64, align: right"]528.95[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [/TABLE]
  16. aragorn
    18,612
    872
    Looking good!
    What else needs done before you get a final tune sorted then get 4wd back?
  17. Bradderz_1988
    3,988
    261
  18. Broken Byzan
    13,237
    466
    <tuffty/> likes this.
  19. Bradderz_1988
    3,988
    261
  20. Broken Byzan
    13,237
    466
    Code:
    [TABLE="width: 709"]
    [TR]
    [TD="width: 64, bgcolor: transparent, align: right"][SIZE=3][COLOR=#000000]21[/COLOR][/SIZE][/TD]
    [TD="width: 64, bgcolor: transparent"][SIZE=3][COLOR=#000000]August[/COLOR][/SIZE][/TD]
    [TD="width: 86, bgcolor: transparent, align: right"][SIZE=3][COLOR=#000000]2013[/COLOR][/SIZE][/TD]
    [TD="class: xl63, width: 64, bgcolor: transparent, align: right"][SIZE=3][COLOR=#000000]18:59:54[/COLOR][/SIZE][/TD]
    [TD="width: 64, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 77, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 33, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 32, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 31, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 83, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 95, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="width: 91, bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent, colspan: 2"][SIZE=3][COLOR=#000000]1.8L R4/5VT     G03 0004[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Group A:[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]'003[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Group B:[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]'020[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Group C:[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]'115[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]RPM[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Mass Flow[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Load[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent, colspan: 2"][SIZE=3][COLOR=#000000]Ign. Timing[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Idle Stabilization[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent, colspan: 2"][SIZE=3][COLOR=#000000]Idle Stabilization[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]Absolute Pres.[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]TIME[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]STAMP[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000] /min[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000] g/s[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000]%[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000] °BTDC[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000] CF[/COLOR][/SIZE][/TD]
    [TD="bgcolor: transparent"][SIZE=3][COLOR=#000000] mbar[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]0.73[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2840[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]20.67[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]12.2[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]31.5[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1.03[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]0[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]0.43[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]39.8[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1010[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1070[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1.64[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2800[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]18.25[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]11[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1.94[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1.34[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]36.1[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1060[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]20.64[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]3960[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]9.19[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]6.3[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]3.8[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]20.95[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]21.25[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]3880[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]11.3[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1040[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]21.55[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]8.81[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]21.85[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]22.16[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]3800[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]16.5[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]22.46[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]64.89[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]49.4[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]28.5[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]22.76[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]23.06[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]4000[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]130.8[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2550[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]1460[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]23.36[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]4120[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]162.56[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]100[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]17.3[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]23.66[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]23.96[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]4480[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]191.7[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2370[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]24.27[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]4680[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]205.25[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]12.8[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]24.57[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]24.87[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]5000[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]25.17[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]5160[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]225.83[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]10.5[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]25.47[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]25.78[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]5480[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2470[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]26.08[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]5680[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]252.75[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]26.38[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]26.68[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]5960[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2440[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]26.98[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]6120[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]263.08[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]27.28[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]27.58[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]6360[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2360[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]27.89[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]6520[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]266.72[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]28.2[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]6760[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]191[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2220[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]28.8[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]6840[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]270.22[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]29.09[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]29.4[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]7040[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2180[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]29.72[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]7160[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]270[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]30[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]30.3[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]7360[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2170[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]30.6[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]7400[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]272.81[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]30.9[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]31.21[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]7320[/COLOR][/SIZE][/TD]
    [TD="class: xl64, bgcolor: #93cddd, align: right"][SIZE=3][COLOR=#000000]2350[/COLOR][/SIZE][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: transparent"][/TD]
    [/TR]
    [/TABLE]
    I may have accidently plugged the N75 back in I have some boost 1.3 bar ish AFR stable . 3rd gear logged as best as possible at hometime.
    WMI is on but only filled with water for additional cooling.
  21. Bradderz_1988
    3,988
    261
    So what figure you seeing then HP wise ?? Also whats the method for calculsting this off the maf g/s ??
  22. Gops
    3,198
    666
    341bhp!
  23. badger5
    9,603
    2,061
    very promising.
    very low ign, no CF... more boosts in there... muaha ha ha haaaaa
    *cough*
  24. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Who said eliminators don't work..
    looks very impressive so far.. Nice work..
  25. Broken Byzan
    13,237
    466
    yup 337 and 280 on B5 rollers today .
    a little to come, perhaps on multi map with banzai wmi dependant map just to see what she can do.
    only things left to do is get some replacement discs as mine are warped a little and it's really noticable now, and fit my shiny wheels if they ever come back...
    logs and plot to come when i remember to ask for it,lol
  26. aragorn
    18,612
    872
    tis awesome to see your finally getting there with the power output! Its taken a while, but things have finally worked out!
    Just need to get it back on 4wd now!
  27. Broken Byzan
    13,237
    466
    and a few logs of before and after
    This was a log with the N75 on on the last file, space for timing and some better fueling up top to allow for additional cooling to aid keeping the EGT's sensible, still need to enable the sensor to see how it's doing. The colour of the manifold seems to point to be it being fecking hot
    Code:
      [TABLE]
      [TR]
       [TD="width: 64"]Friday[/TD]
       [TD="width: 64, align: right"]23[/TD]
       [TD="width: 64"]August[/TD]
       [TD="width: 64"]15:33:40:41334[/TD]
       [TD="width: 64"]VCDS Version: Release 11.11.6[/TD]
       [TD="width: 192, colspan: 3"]Data version:   20121223[/TD]
      [/TR]
      [TR]
       [TD="colspan: 2"]8N0 906 018   H[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD]Group A:[/TD]
       [TD]'003[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD]Group B:[/TD]
       [TD]'020[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD]Group C:[/TD]
       [TD]'118[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD][/TD]
       [TD]Engine Speed[/TD]
       [TD]Mass Air Flow[/TD]
       [TD]Throttle Valve Angle[/TD]
       [TD]Ignition[/TD]
       [TD][/TD]
       [TD]Timing Retardation[/TD]
       [TD="colspan: 2"]Timing Retardation[/TD]
       [TD]Intake Air[/TD]
       [TD]Boost Pressure[/TD]
       [TD="colspan: 2"]Boost Pressure[/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD]TIME[/TD]
       [TD](G28)[/TD]
       [TD="colspan: 2"]Sensor (G70)[/TD]
       [TD]Timing Angle[/TD]
       [TD]TIME[/TD]
       [TD]Cylinder 1[/TD]
       [TD]Cylinder 2[/TD]
       [TD]Cylinder 3[/TD]
       [TD]Cylinder 4[/TD]
       [TD]TIME[/TD]
       [TD](G28)[/TD]
       [TD]Temperature (G42)[/TD]
       [TD]Control (N75)[/TD]
       [TD](actual)[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD]Marker[/TD]
       [TD]STAMP[/TD]
       [TD] /min[/TD]
       [TD] g/s[/TD]
       [TD] %[/TD]
       [TD] °BTDC[/TD]
       [TD]STAMP[/TD]
       [TD]°KW[/TD]
       [TD]°KW[/TD]
       [TD]°KW[/TD]
       [TD]°KW[/TD]
       [TD]STAMP[/TD]
       [TD] /min[/TD]
       [TD]°C[/TD]
       [TD] %[/TD]
       [TD] mbar[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]14.49[/TD]
       [TD="align: right"]1680[/TD]
       [TD="align: right"]24.08[/TD]
       [TD="align: right"]21.2[/TD]
       [TD="align: right"]16.5[/TD]
       [TD="align: right"]14.8[/TD]
       [TD="align: right"]0[/TD]
       [TD="align: right"]15.1[/TD]
       [TD="align: right"]30[/TD]
       [TD="align: right"]95.3[/TD]
       [TD="align: right"]1100[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]15.39[/TD]
       [TD="align: right"]29.36[/TD]
       [TD="align: right"]78.4[/TD]
       [TD="align: right"]14.3[/TD]
       [TD="align: right"]15.7[/TD]
       [TD="align: right"]15.99[/TD]
       [TD="align: right"]1720[/TD]
       [TD="align: right"]1130[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]16.29[/TD]
       [TD="align: right"]30.14[/TD]
       [TD="align: right"]12.8[/TD]
       [TD="align: right"]16.61[/TD]
       [TD="align: right"]16.91[/TD]
       [TD="align: right"]27[/TD]
       [TD="align: right"]1150[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]17.2[/TD]
       [TD="align: right"]28.89[/TD]
       [TD="align: right"]78.8[/TD]
       [TD="align: right"]12[/TD]
       [TD="align: right"]17.5[/TD]
       [TD="align: right"]17.8[/TD]
       [TD="align: right"]1960[/TD]
       [TD="align: right"]1170[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]18.1[/TD]
       [TD="align: right"]2120[/TD]
       [TD="align: right"]42.03[/TD]
       [TD="align: right"]94.9[/TD]
       [TD="align: right"]18.41[/TD]
       [TD="align: right"]18.72[/TD]
       [TD="align: right"]2400[/TD]
       [TD="align: right"]52.2[/TD]
       [TD="align: right"]1260[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]19.02[/TD]
       [TD="align: right"]2520[/TD]
       [TD="align: right"]56.56[/TD]
       [TD="align: right"]17.3[/TD]
       [TD="align: right"]19.31[/TD]
       [TD="align: right"]19.62[/TD]
       [TD="align: right"]2840[/TD]
       [TD="align: right"]42[/TD]
       [TD="align: right"]1430[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]19.92[/TD]
       [TD="align: right"]2960[/TD]
       [TD="align: right"]80.61[/TD]
       [TD="align: right"]99.6[/TD]
       [TD="align: right"]15[/TD]
       [TD="align: right"]20.23[/TD]
       [TD="align: right"]20.52[/TD]
       [TD="align: right"]3280[/TD]
       [TD="align: right"]40[/TD]
       [TD="align: right"]1850[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]20.83[/TD]
       [TD="align: right"]3440[/TD]
       [TD="align: right"]129.94[/TD]
       [TD="align: right"]100[/TD]
       [TD="align: right"]21.12[/TD]
       [TD="align: right"]21.43[/TD]
       [TD="align: right"]3760[/TD]
       [TD="align: right"]29[/TD]
       [TD="align: right"]2260[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]21.73[/TD]
       [TD="align: right"]3920[/TD]
       [TD="align: right"]155.83[/TD]
       [TD="align: right"]22.03[/TD]
       [TD="align: right"]22.34[/TD]
       [TD="align: right"]4160[/TD]
       [TD="align: right"]2340[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]22.64[/TD]
       [TD="align: right"]4280[/TD]
       [TD="align: right"]179.06[/TD]
       [TD="align: right"]22.94[/TD]
       [TD="align: right"]23.24[/TD]
       [TD="align: right"]4560[/TD]
       [TD="align: right"]40.8[/TD]
       [TD="align: right"]2380[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]23.54[/TD]
       [TD="align: right"]4680[/TD]
       [TD="align: right"]195.69[/TD]
       [TD="align: right"]23.85[/TD]
       [TD="align: right"]24.15[/TD]
       [TD="align: right"]4920[/TD]
       [TD="align: right"]44.3[/TD]
       [TD="align: right"]2440[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]24.45[/TD]
       [TD="align: right"]5000[/TD]
       [TD="align: right"]223.64[/TD]
       [TD="align: right"]10.5[/TD]
       [TD="align: right"]24.75[/TD]
       [TD="align: right"]25.05[/TD]
       [TD="align: right"]5320[/TD]
       [TD="align: right"]32[/TD]
       [TD="align: right"]45.1[/TD]
       [TD="align: right"]2470[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]25.36[/TD]
       [TD="align: right"]5440[/TD]
       [TD="align: right"]243.89[/TD]
       [TD="align: right"]25.66[/TD]
       [TD="align: right"]25.96[/TD]
       [TD="align: right"]5720[/TD]
       [TD="align: right"]33[/TD]
       [TD="align: right"]2450[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]26.26[/TD]
       [TD="align: right"]5840[/TD]
       [TD="align: right"]253.78[/TD]
       [TD="align: right"]9.8[/TD]
       [TD="align: right"]26.56[/TD]
       [TD="align: right"]26.86[/TD]
       [TD="align: right"]6080[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]27.16[/TD]
       [TD="align: right"]6200[/TD]
       [TD="align: right"]259.44[/TD]
       [TD="align: right"]27.47[/TD]
       [TD="align: right"]27.77[/TD]
       [TD="align: right"]6400[/TD]
       [TD="align: right"]2290[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]28.07[/TD]
       [TD="align: right"]6520[/TD]
       [TD="align: right"]264.58[/TD]
       [TD="align: right"]28.37[/TD]
       [TD="align: right"]28.67[/TD]
       [TD="align: right"]6800[/TD]
       [TD="align: right"]34[/TD]
       [TD="align: right"]2210[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]28.97[/TD]
       [TD="align: right"]6920[/TD]
       [TD="align: right"]266.11[/TD]
       [TD="align: right"]11.3[/TD]
       [TD="align: right"]29.28[/TD]
       [TD="align: right"]29.58[/TD]
       [TD="align: right"]7160[/TD]
       [TD="align: right"]2160[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]29.88[/TD]
       [TD="align: right"]7240[/TD]
       [TD="align: right"]267.14[/TD]
       [TD="align: right"]30.18[/TD]
       [TD="align: right"]30.48[/TD]
       [TD="align: right"]7480[/TD]
       [TD="align: right"]35[/TD]
       [TD="align: right"]2100[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]30.79[/TD]
       [TD="align: right"]7360[/TD]
       [TD="align: right"]260.56[/TD]
       [TD="align: right"]54.9[/TD]
       [TD="align: right"]-7.5[/TD]
       [TD="align: right"]31.1[/TD]
       [TD="align: right"]31.39[/TD]
       [TD="align: right"]6000[/TD]
       [TD="align: right"]1370[/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
     [/TABLE]
    Code:
      [TABLE]
      [TR]
       [TD="width: 64"]17:34:05:41334[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD]Group A:[/TD]
       [TD]'003[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD]Group B:[/TD]
       [TD]'020[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
       [TD]Group C:[/TD]
       [TD]'118[/TD]
       [TD][/TD]
       [TD][/TD]
       [TD][/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD][/TD]
       [TD]Ignition[/TD]
       [TD][/TD]
       [TD]Intake Air[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD]TIME[/TD]
       [TD](G28)[/TD]
       [TD]TIME[/TD]
       [TD]Cylinder 1[/TD]
       [TD]Cylinder 2[/TD]
       [TD]Cylinder 3[/TD]
       [TD]Cylinder 4[/TD]
       [TD]TIME[/TD]
       [TD](G28)[/TD]
       [TD](actual)[/TD]
      [/TR]
      [TR]
       [TD]Marker[/TD]
       [TD]STAMP[/TD]
       [TD] /min[/TD]
       [TD] g/s[/TD]
       [TD] %[/TD]
       [TD] °BTDC[/TD]
       [TD]STAMP[/TD]
       [TD]°KW[/TD]
       [TD]°KW[/TD]
       [TD]°KW[/TD]
       [TD]°KW[/TD]
       [TD]STAMP[/TD]
       [TD] /min[/TD]
       [TD]°C[/TD]
       [TD] %[/TD]
       [TD] mbar[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]0.3[/TD]
       [TD="align: right"]1600[/TD]
       [TD="align: right"]14.17[/TD]
       [TD="align: right"]29.3[/TD]
       [TD="align: right"]0.62[/TD]
       [TD="align: right"]0.02[/TD]
       [TD="align: right"]1030[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]1.24[/TD]
       [TD="align: right"]14.19[/TD]
       [TD="align: right"]1.51[/TD]
       [TD="align: right"]0.9[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]2.11[/TD]
       [TD="align: right"]14.03[/TD]
       [TD="align: right"]2.42[/TD]
       [TD="align: right"]1.82[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]3.03[/TD]
       [TD="align: right"]13.94[/TD]
       [TD="align: right"]3.32[/TD]
       [TD="align: right"]2.71[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]3.93[/TD]
       [TD="align: right"]14.31[/TD]
       [TD="align: right"]27.8[/TD]
       [TD="align: right"]4.22[/TD]
       [TD="align: right"]3.62[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]4.83[/TD]
       [TD="align: right"]14[/TD]
       [TD="align: right"]5.13[/TD]
       [TD="align: right"]4.52[/TD]
      [/TR]
      [TR]
       [TD="align: right"]1[/TD]
       [TD="align: right"]5.73[/TD]
       [TD="align: right"]14.89[/TD]
       [TD="align: right"]10.2[/TD]
       [TD="align: right"]28.5[/TD]
       [TD="align: right"]6.04[/TD]
       [TD="align: right"]5.44[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]6.64[/TD]
       [TD="align: right"]1640[/TD]
       [TD="align: right"]23.83[/TD]
       [TD="align: right"]20.3[/TD]
       [TD="align: right"]6.94[/TD]
       [TD="align: right"]6.34[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]7.55[/TD]
       [TD="align: right"]28.36[/TD]
       [TD="align: right"]7.84[/TD]
       [TD="align: right"]7.25[/TD]
       [TD="align: right"]1060[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]8.45[/TD]
       [TD="align: right"]26.83[/TD]
       [TD="align: right"]8.75[/TD]
       [TD="align: right"]8.15[/TD]
       [TD="align: right"]31[/TD]
       [TD="align: right"]1090[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]9.36[/TD]
       [TD="align: right"]2040[/TD]
       [TD="align: right"]37.31[/TD]
       [TD="align: right"]15.8[/TD]
       [TD="align: right"]9.66[/TD]
       [TD="align: right"]9.05[/TD]
       [TD="align: right"]1880[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]10.27[/TD]
       [TD="align: right"]2480[/TD]
       [TD="align: right"]51[/TD]
       [TD="align: right"]18[/TD]
       [TD="align: right"]10.57[/TD]
       [TD="align: right"]9.97[/TD]
       [TD="align: right"]2320[/TD]
       [TD="align: right"]73.3[/TD]
       [TD="align: right"]1210[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]11.17[/TD]
       [TD="align: right"]2880[/TD]
       [TD="align: right"]71.06[/TD]
       [TD="align: right"]11.47[/TD]
       [TD="align: right"]10.87[/TD]
       [TD="align: right"]2760[/TD]
       [TD="align: right"]1340[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]12.08[/TD]
       [TD="align: right"]3360[/TD]
       [TD="align: right"]112[/TD]
       [TD="align: right"]19.5[/TD]
       [TD="align: right"]12.38[/TD]
       [TD="align: right"]11.78[/TD]
       [TD="align: right"]3200[/TD]
       [TD="align: right"]1630[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]12.98[/TD]
       [TD="align: right"]3880[/TD]
       [TD="align: right"]163.81[/TD]
       [TD="align: right"]13.28[/TD]
       [TD="align: right"]12.68[/TD]
       [TD="align: right"]3680[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]13.89[/TD]
       [TD="align: right"]4360[/TD]
       [TD="align: right"]183.58[/TD]
       [TD="align: right"]3[/TD]
       [TD="align: right"]13.59[/TD]
       [TD="align: right"]4240[/TD]
       [TD="align: right"]2390[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]14.79[/TD]
       [TD="align: right"]4800[/TD]
       [TD="align: right"]217.58[/TD]
       [TD="align: right"]4640[/TD]
       [TD="align: right"]26[/TD]
       [TD="align: right"]2410[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]5200[/TD]
       [TD="align: right"]234.89[/TD]
       [TD="align: right"]16[/TD]
       [TD="align: right"]2.3[/TD]
       [TD="align: right"]15.4[/TD]
       [TD="align: right"]5080[/TD]
       [TD="align: right"]44.7[/TD]
       [TD="align: right"]2430[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]16.6[/TD]
       [TD="align: right"]5600[/TD]
       [TD="align: right"]246.94[/TD]
       [TD="align: right"]16.3[/TD]
       [TD="align: right"]5480[/TD]
       [TD="align: right"]43.5[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]17.51[/TD]
       [TD="align: right"]5960[/TD]
       [TD="align: right"]255.89[/TD]
       [TD="align: right"]18.8[/TD]
       [TD="align: right"]17.81[/TD]
       [TD="align: right"]1.5[/TD]
       [TD="align: right"]17.21[/TD]
       [TD="align: right"]49.8[/TD]
       [TD="align: right"]2350[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]6320[/TD]
       [TD="align: right"]263.89[/TD]
       [TD="align: right"]18.71[/TD]
       [TD="align: right"]18.11[/TD]
       [TD="align: right"]58[/TD]
       [TD="align: right"]2270[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]19.32[/TD]
       [TD="align: right"]6680[/TD]
       [TD="align: right"]19.63[/TD]
       [TD="align: right"]0.8[/TD]
       [TD="align: right"]6560[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]20.22[/TD]
       [TD="align: right"]7000[/TD]
       [TD="align: right"]271.25[/TD]
       [TD="align: right"]20.53[/TD]
       [TD="align: right"]6880[/TD]
       [TD="align: right"]2200[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]21.13[/TD]
       [TD="align: right"]7320[/TD]
       [TD="align: right"]272.28[/TD]
       [TD="align: right"]7200[/TD]
      [/TR]
      [TR]
       [TD][/TD]
       [TD="align: right"]22.04[/TD]
       [TD="align: right"]7680[/TD]
       [TD="align: right"]273.33[/TD]
       [TD="align: right"]7560[/TD]
      [/TR]
     [/TABLE]
    after some timing and boost stabilisation
  28. Bradderz_1988
    3,988
    261
    Thats some good bhp/torque to have some fun with !!
    So whats next in the process mark ?? You almost there ??
    you popping it back to 4WD now or still more fine tuning to do whilst 2WD ??
  29. Broken Byzan
    13,237
    466
    I think i'll tidy it up stuff the proper diff back in and sell her on. 50/50 atm.
    No more upgrades i just cannot afford them, I wish i'd chosen a larger frame turbo I have built an engine capable of supplying 500 bhp and it's barely idling...
    If she goes, it will be for something very std and boring.
  30. Bradderz_1988
    3,988
    261
    sell WTF you taking the **** !!
    break the damn thing if anything !! You will probably get more for it in parts !!
    AR-rkon likes this.
  31. Sulli79
    Sulli79 Active Member
    541
    37
    No way, keep it and enjoy all the effort you have put in!!
    ScottD3 likes this.
  32. aragorn
    18,612
    872
    Really is no point selling it! You'll get ****e all back compared with what you've put in.
    Drive, Enjoy.
  33. Broken Byzan
    13,237
    466
    From them
    to them.
    :respekt:
    Now thanks to Matt @ Cat cams for sending me the replacement bolts for my cam gears i am hoping to fix the mechanical cam to cam timing because it's showing as 11-12 degrees out.
    Wheels are back from machine shop, I just need to fix my mullered wing to enable satisfactory fitment . They removed 12mm from the back, so with a slight flare I recon we are good to go
    ScottD3 likes this.
  34. Broken Byzan
    13,237
    466
    Some phone snaps after their annual wash.
    They both need some TLC but moving and having a roof over our heads seemed to be more important
    AlexGSi2000 and Lee Goodall like this.
  35. Broken Byzan
    13,237
    466
    Nothing good to report, I managed to score a pair of front wings in the same colour in much better condition than mine so i'll roll them and nail them on when I get some motivations back.
    She just needed some tidying but my rattle has come back, so I had had to purchase some more rods to eliminate downtime during the swap over. At the same time I am putting another crank in just to be sure/ Parts are mostly collected for that project until....
    Can you guess what it is yet......
    This may delay things a bit, I was kind of hoping to fix the rattle and be done, it seems the turbo fairy had other ideas
  36. Bradderz_1988
    3,988
    261
    That doesnt sound good, is that the turbo on engine cut off making that noise ??
    Havent you just swapped the oil pump hows the oil pressure ??
  37. Broken Byzan
    13,237
    466
    Dan @ beach buggy has come up trumps.
    I am using my spare chra I kept and having this shiny lot fitted to it.
    Std comp wheel and gt 30 turbine (57mm by 52mm) I need to get my fubar turbo off to BBT to allow for the turbine housing to be machined to match.
    We have been trying to locate an upgrade bearing pack, Owens do one but i believe they will only fit at point of turbo repair or purchase.
    I have found these guys.. New silicone nitride ball bearing packs available | Turbocare..
    I might go for it of my bearing is broken, but if mine is perfect as it should be, I'll hang on till a reliably sourced unit is available for possible future upgrade. With these guys it's around £212 plus carriage delivered, with brass bearing cages
  38. Bradderz_1988
    3,988
    261
    That will give some good hp figures :) !!
    Are you selling up or not make your bloody mind up lol
  39. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Keep it and make it better :)
    I keep dabbling with changing mine but it still scrubs up well even with its age and miles.
  40. Broken Byzan
    13,237
    466
    It's official the turbo is broken/dead/fubar. Replacement turbine and Comp wheel were going to be the order of the day, but it turned out my housing was beyond repair. So the closest thing available is a gt30 compact style housing. That should mean the CHRA will drop in direct, but my manifold, downpipes and that will need tweaking.
    There are other options on the table being explored
    The engine is in bit and the crank was checked and found to be perfect. This has led to a dilemma because I know it had a noise i want to track down, but I was hoping to see something wrong.
    I am aiming to change the IM bearings while i'm in the engine as it has since come to light that they are available.
    I have also resolved my bodywork "issue"
    and it seems my seats have fallen out.....
    I wonder why?
