TQS factory xenons pointing too high
Nick101 Dec 15, 2012
  1. Nick101
    Nick101 Boost fiend
    211
    15
    Hi folks, had a few cars flashing me and this morning a bloke got out of his car at a set of lights to tell me my lights here dazzling him, he also mentioned it looked as if they were bouncing as I was driving along?
    as the title says its a 99 (T) TQS with factory fitted xenons, how do I go about checking and adjusting then?
    When I turn them on try don't go up and down like other cars I have had with xenons, could this be a clue?
  2. Broken Byzan
    13,237
    465
    id assume its a broken axle sensor, youd need to look and see if the arms are still connected to the wishbones. If you scan the xenon module it should show up. for now i'd adjust them to a sensible height manually for now
  3. Nick101
    Nick101 Boost fiend
    211
    15
    Are the adjuster arms connected to both front wish bones? I'm sure I have seen one on the driver side rear.
  4. Broken Byzan
    13,237
    465
    passenger side front lower and passenger side rear lower. They should have plastic little arm connected to them, but they have a habit of snapping when the balljoint siezes on the one end of it
  5. Nick101
    Nick101 Boost fiend
    211
    15
    Ok thanks mate, I'll have a look. For now think I'll just manually adjust them. Isit the 2 white cross head screws of the far left/right of each headlight?
    I had my timing belt done a week or so ago, front end off jobbie, do you think they have disturbed something when doing this? As I have not had a problem untill now.
  6. Broken Byzan
    13,237
    465
    maybe they set them back on too high on the bolts. The inside of the 2 screws does the height, the outer does the left/right
  7. CraigG
    CraigG Member
    190
    if they were "bouncing" its possible that the light unit inside has came loose from the adjustment motors
    if it was a broken angle sensor, the "limp mode" is that it will set the lights to the lowest possible setting, and flag a code (had this on my old S4).
  8. Nick101
    Nick101 Boost fiend
    211
    15
    I haven't noticed them bouncing to be honest, xenons can give the illusion they are moving then coming towards/following you because of bumps on the road causing the beam to move.
    i have manually adjusted them for now? Seem a lot better and had no one flashing me ect. Cheers folks!
