tqs ABS Sensors
jcb Nov 24, 2010
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    Nov 99 1.8tqs
    have been given a part number of 8D0 927807F and quoted everything from £83 to £137!!
    WTF!?
    firstly is this the right part number and secondly where do people get their ABS Sensors?
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    I got a front one off eBay for about £16 I think. Works fine.
  3. aragorn
    18,300
    805
    8D0927807F is a rear sensor for a facelift quattro (bolt in).
    They are £133 from Audi, and quite hard to find aftermarket.
    You can use a push in front sensor (as ian says they're available for buttons) along with the copper sleeve (pn:443927817) and mong the loom about so it fits.
    This is what i'm using on the rear of mine, after i destroyed a perfectly good sensor (it was a broken reluctor, but i only figured that out after the sensor was in pieces on the floor!)
  4. ian52
    1,199
    Its a bit of a **** design if you ask me. Mine was a nightmare to get out.
  5. electricracer
    electricracer Member
    149
    just buy a non quattro one i found only difference to be the grommets on cable, no modding required just plugged straight in £16 on evilbay
  6. Broken Byzan
    13,237
    465
    I have a spare non bolt in one here you can adjust if you need one?
    I can post it up tomoz if you PM your address
  7. jcb
    4,132
    13
    ah, just the job, buggered if I am dropping £260 on parts I may not bloody need.
    Mark , you have PM
    I have given up trying to remove them in one peice, much easier to just smash the tops off and drill the centres out. save me hours of f2cking around
  8. jcb
    4,132
    13
    ha, just found 2 proper bolt in facelift OEM ones for £90!! bargain!
    will still take your front oen though Mark. let me know
  9. Broken Byzan
    13,237
    465
    Yeah you can have it mate. I will try and make the PO after college
