TPMS (Tyre Pressure Monitoring System)
c_w Mar 7, 2012
  1. c_w
    c_w Well-Known Member
    1,168
    90
    Have read that this is quite a simple retrofit consisting of essentially a TPMS switch for the dash, a few wires and coding? I'm just wondering if anyone has this fitted, does the switch light up to match the dash when the lights are on (ie like the ESP OFF switch)?
    The switch is around £13 from AUDI
    8P0927121 5PR TPMS switch (single DIN radio 04-08)
    8P0927121A 5PR TPMS switch (double DIN radio 04-08)
    4D0971636A Switch plug
    000979009 Repair wires
  2. JS3
    JS3 Member VCDS Map User
    227
    I would be interested in this too - sounds a little too simple to me though...!
  3. urq
    urq New Member
    21
  4. NHN
    29,561
    1,778
    You need to check if your abs controller supports it 1st before doing anything else.
    Button lights up at night red as part of illumination circuit, but it simply when depressed lights up momentarily on the dash with a beep & when you have a lesser rolling circumference warns you via a lamp in cluster, newer systems on the 8P have dis based warning & setting system via MF stalk with no button.
  5. sachen
    sachen Member
    246
    Hi Nigel.
    I have a 06 plate 2.0TDI. Would my abs controller be able to support this?
    Thanks in advance.
  6. NHN
    29,561
    1,778
    When your vcds arrives you'd need to check part no. of abs against what etka says it can do.
  7. JS3
    227
    Guys - sounds as though this is a go-er. Unfortunately I am not into the buzz words like VCDS or EKTA so would need to somebody to steer me in the right direction.
    I have a 2010 S3 - would this be workable?
  8. sachen
    sachen Member
    246
    Cheers... I may ask for your help if I dont know how to check that...!?:)
  9. minimadmotorman
    minimadmotorman Member
    189
    10
    So could my brand new black edition have TPMS enabled through the dis via VCDS?
    No need for a button and could reset it through the DIS?
  10. NHN
    29,561
    1,778
    Please read my last post again people asking if there car can do it!!
  11. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    VCDS is a cable and the software is downloaded to your laptop.
    It is similar to what the dealers use. You can code, scan, fault find etc etc.
    IMHO every vag car owner should own one if they intend with staying in the vag group for a long time. Can save you hundreds in the long run.
    PM NHN as he is the main man for selling genuine cables. Not the cheapest cable, but well worth it in the long run and you will find Nigel(NHN) sells at a good price.
    EKTA is an electronic parts catalogue also used on the laptop/pc again used by dealers to get part numbers etc. you can buy copies of this from fleebay.
    Hope this helps.
  12. JS3
    227
    Thanks for the pointers! Always learning....
  13. NHN
    29,561
    1,778
    Sorry missed that bit, but Danny has given the info, kudo's :)
  14. sachen
    sachen Member
    246
    Does anyone know how I am able to check whether my ABS controller supports TPMS through VCDS?
  15. NHN
    29,561
    1,778
    You'd need to check etka tbh.
  16. sachen
    sachen Member
    246
    i have a copy of etka. what do i have to check for?
  17. NHN
    29,561
    1,778
    You have to know about PR-codes & know how to find info within etka really.
  18. sachen
    sachen Member
    246
    any chance youll be able to help me out to find if mine is compatible?
  19. NHN
    29,561
    1,778
    Part no?
  20. sachen
    sachen Member
    246
    just to see if my current abs unit is compatible if i decide to put in tpms
  21. NHN
    29,561
    1,778
    Huh, I asked for your part no.
  22. sachen
    sachen Member
    246
    ahh sorry dude didnt understand you at first. will scan tomorrow and let you know the part number. thanks for your help.
  23. sachen
    sachen Member
    246
    Hi Nige,
    Just checked for the part number and I believe it is this:
    1K0 907 379 AA
    Cheers,
    Sach
  24. NHN
    29,561
    1,778
    Its not actually advising as it supersedes to another module which also isnt advising to well, I would try & code the option & see if it rejects the coding.
  25. sachen
    sachen Member
    246
    Ahh cool. Cheers. So if I code the option and it doesnt reject the code, hopefully should mean that it is compatible?
  26. NHN
    29,561
    1,778
    If accepts then its more than 50% chance will work, but tbh mate, just code, if accepts, stick a wire in the right slot & iirc a 12v 5 second touch should simulate the button being pressed & see if it beeps on the cluster, if so then tpms will work, needs about 100 km's to calibrate though.
  27. N8
    17,163
    719
    Still need to get round to fitting mine properly, ey nige :laugh:
  28. NHN
    29,561
    1,778
    Oh yeah lol, but need abs controller changing 1st.
  29. N8
    17,163
    719
    Will check etka 2mor :laugh:
