TPMS Malfunction
audia4kev Sep 19, 2012
  1. audia4kev
    audia4kev New Member
    Have being getting this warning beeb and lamp in the instrument cluster. When the ignition is switch on for about 20 minutes, would any of you guys have any idea what could be the cause of this. is this a common problem. any help would be much appreciated. kev
  2. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    Is this for real?????
  3. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    Tyre pressure monitoring system... You got yourself a puncture by the sounds of it!
  4. audia4kev
    i taught that too but no sign of a puncture the flashes for about 1minute and stays on
    . any other ideas
  5. toastyhamster
    toastyhamster Member
    166
    9
    You've got a puncture! Doesn't need to be a flat, from memory it's about a 4psi drop.
  6. NHN
    29,300
    1,702
    You are kidding me with this question?
    Have you even checked the air pressures in each tyre yet?
    johnnythepie likes this.
  7. Pyeman
    Pyeman Member VCDS Map User quattro Audi A6 Audi Avant Owner Group TDi
    183
    20
    :sign_omg: :haudrauf:
  8. riggssuzuki
    riggssuzuki Active Member
    496
    57
    Seriously?????
  9. johnnythepie
    2,242
    75
    FFS I thought it was just me........
  10. audia4kev
    have checked tyre pressure and there is nothing wrong with them. they are all 29psi. so now genius that s not the problem.
  11. Spr0cket
    Spr0cket Member
    114
    Having checked the pressures are all good (although typically front and rear should nopt be same). It would be wise to relearn those stored values - button presses in MMI. All being 29 means nothing, unless you are absolutely confident they were all at that exact pressure when the sytstem was calibrated to reference.
    1. So start by checking what correct pressure should be - sticker on drivers door edge.
    2. Pump the tyres to the required pressures.
    3. Reset TPMS to that validated referfence point via MMI.
    See what happens.
  12. riggssuzuki
    496
    57
    Be aware that depending on your car the tyre pressures may be incorrect. The 19" wheels on mine (as fitted standard on the Dynamik) are not catered for on the sticker. Doh! I had my light come on and it just needed a check of pressures and a re set.
  13. johnnythepie
    2,242
    75
    As per Spr0cket
    1.Read Owners Manual
    2.Ensure correct pressure is in all tyres.29 is not correct for starters.
    3.Reset TMPS in MMI.
    4.If TMPS light comes on after a drive, check pressures.If pressures are what you put in, THEN you have a problem.Basics first.
    5.Genius status not required for above steps.
  14. Pyeman
    183
    20
    lmfao.
  15. NHN
    29,300
    1,702
    LMAO, now now, I think the replies were a little expected given the original post.
    Ok so it actually states malfunction in the dis, not warning of tyre pressures, in this circumstance it needs to be scanned & if its under warranty, just take it to audi, obviously after checking tpms in mmi :)
  16. Zafi
    Zafi Well-Known Member
    1,245
    307
    Have you recently fitted just one tyre?
  17. audia4kev
    yes its says malfunction in the dis. no tyre change or no drop in tyre pressure. going to take it to audi to get it sorted. thanks for the help.
  18. johnnythepie
    2,242
    75
    well why didnt you say that it said malfunction in the dis?? :banghead:
  19. Pyeman
    183
    20
  20. riggssuzuki
    496
    57
    Oh for the love of......... :keule:
  21. audia4kev
    have had car in and out of audi 3 times to sort this problem. with them ending up changing the handbrake module to solve this problem.
  22. riggssuzuki
    496
    57
    Can i respectfully request that when people put up an issue they state ALL the facts. Otherwise you can come across as a little 'un-informed'. THe slight hints of sarcasm earlier on were down to insufficient details on the problem you was experiencing.
