Toyosport downpipe and decat
puggsy21 Nov 2, 2013
  1. puggsy21
    puggsy21 Member
    97
    hey all,
    so today i fitted my new discs and brake pads which are alot better got grooved and dimpled all round and new pads plus i fitted my toyosport downpipe and decat and added my miltek cat back system need some exhaust paste where the pipe joins are :)
    My question is i went to take the car out for a spin see how the brakes and exhaust are but on pulling away i could hear what sounded like the driveshaft rubbing against the downpipe as it gets louder when you use more throttle i didnt go far, 50 yards or so once i heard noise i parked it back up
    what is my best or easiest option to correct the issue and would i need to take downpipe back off.
    Cheers for any responses
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    Best bet would be to get under it and see if there is any telltale rub marks :) then take it from there as to how and where to move...
  3. Scullies
    Scullies Well-Known Member
    1,543
    657
    my relentless also rubbed on my ko4 setup. I manage to fit the hanger pin through the center of the rubber bushing. Took some effort to get it in there.
  4. puggsy21
    puggsy21 Member
    97
    Scullies which hanger/rubber bushing are you referring to
  5. Scullies
    1,543
    657
    on the relentless DP there is a rod that sticks out off to the side of the pipe, before it joins the cat or decat. It fits into the stock exhaust rubber support.
    I managed to raise the DP a little bit up towards the floorpan, by fitting the rod into the center of the rubber support. Its not meant to fit in that position though.
  6. puggsy21
    puggsy21 Member
    97
    here is the one i have got it doesnt have the hanger like yours does
  7. Scullies
    1,543
    657
    aah you have an A3. I assumed you had a S3 when I read that the flexi was rubbing on the drive shaft. Blonde moment.
  8. puggsy21
    puggsy21 Member
    97
    lol ha ha, so do you think that is happening to mine the flexi rubbing on the drivershaft
  9. Scullies
    1,543
    657
    I really don't know bud, best to have a look where the flexi is sitting
  10. m19lte
    m19lte Member
    123
    Get under the car mate (when exhaust is cold) and move/rattle it about up and down - left to right, then see where it touches. There's usually some movement in brackets so-on.
  11. puggsy21
    puggsy21 Member
    97
    ok cool will do cant do it at the min as not feeling well
  12. <tuffty/>
    21,155
    3,835
    Tactical dent where it rubs... FWD or quattro?
  13. puggsy21
    puggsy21 Member
    97
    FWD tuffty
