Towbar wiring faults
Rayeman
Hi All,I am hoping someone can help, I have a 2012 A3 S-Line which I have just fitted a Witter towbar kit to along with an aftermarket universal bypass relay wiring kit. Followed all the instructions which were pretty straight forward. However, once I had completed the install, I then turned the ignition on only to find a number of faults inc stabilisation fault, air bag fault and power steering fault. Can anyone advise on what this might be and do I need to get it Audi to have these reset?ThanksPaul
Did you disconnect the battery when wiring in the towbar?
If yes, the air at light will need clearing with VCDS or similar. The steering/ stability lights will more than likely be on due to the steering angle sensor need its basic settings performed. Try starting the engine then turn the wheel slowly to left lock and hold it it there for a couple of seconds, then turn the wheel slowly to right lock and hold it a couple of seconds then return the wheel to centre. After that without switching the engine off, take it for a drive.
