tow bar issue
stuhow3361 Jul 3, 2010
  1. stuhow3361
    stuhow3361 Member
    210
    14
    bought my avant with a "quick release" pct bar fitted.any ideas how to get it off? i've drilled out the lock since i was told i had the wrong keys but th big black release wheel still will not turn.i want to keep the bar but would also like it off when not in use.
  2. scott b
    scott b Active Member VCDS Map User
    1,254
    try pulling the handle out then twisting the handle, if you had said befor hand i could of got replacement keys for you
  3. Tooks
    Tooks Active Member
    753
    30
    Is it the Audi one? I've just been and had a look at mine, and you have to pull the black knob/wheel out and then turn it. The neck should then just fall out and it will be 'primed' ready for refitting next time?
  4. stuhow3361
    stuhow3361 Member
    210
    14
    No, it's a PCT bar.The wheel does pull out slightly but does not turn either way.
  5. scott b
    1,254
    what you may be able to do then is get a full on replacement neck, as if you look up where the neck locates, the ousing should be bolted on.
