Touching with 19 inch wheels
zaeem Nov 29, 2012
  1. zaeem
    zaeem Active Member
    101
    58
    Hi guys i just fitted rs6 reps et45 tire size is 235/35/19. My car is touching when i drive over bumps. Any remedies for this ?
  2. zaeem
    zaeem Active Member
    101
    58
    I drive an s3 sportback with eibach front springs only
  3. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    Wheel width and offset?
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    225 tyres
  5. zaeem
    zaeem Active Member
    101
    58
    8,5 j et 45
    Someone mentioned to me about a screw that must be removed does anyone have a pic of this screw
  6. zaeem
    zaeem Active Member
    101
    58
    225 tyres looked to stretched on the rims
  7. Acheron
    Acheron Active Member
    271
    30
    Are you touching in the front or the back? You can't miss the screw you need to remove, it's right on the edge of the wheel arch and looks far more raised than the rest.
  8. Djwoody
    Djwoody Member
    481
    21
    I removed a screw at the weekend, but it was in the middle at the top of the arch. Is this the right one?
  9. N8
    17,163
    718
    Slimmer tyres, camber.
  10. Acheron
    271
    30
    Yeah, that's the one, by "edge" I meant right against the outside of the arch ;)
  11. Shadowman
    Shadowman Active Member
    592
    43
    As N8 says, with that size and offset, you are going to struggle not to rub with 235's...you need to run 225's and then you won't have any issues, and they aren't much of a stretch...loads of the guys on here run them with no issues.
  12. tcardio
    tcardio Well-Known Member
    992
    287
    225 bro! if your not rubbin then you aren't dubbin
  13. Ash187
    7,505
    748
    I have 225/35/19 on my rs6-2 et42 8.5j alloys
    no rubbing until I have a fatty in the back
  14. Biggy
    Biggy Member
    115
    13
    I got a 225 on a 9.5 inch rim on the back, so I'm sure you'll be fine on a 8.5 inch rim dude
  15. MartayMcFly
    2,763
    354
    I had 225/35 on 8.5 ET44 at the front, ET48 at the rear with no rubbing. You don't get any side-wall protection, so wheels kerb easily, but no rubbing.
