Torque Wrench
Yannis Nov 26, 2013
  1. Yannis
    Yannis Member
    65
    I'm looking at buying a torque wrench and wanted to know what range of torque is good?
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,520
    660
  3. RS5UK
    RS5UK Member
    What do you want to use it for? As a general wrench a 60-300 is great. If its engine work you might need an 8-60 for the likes of head bolts etc.
  4. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    smaller ones tend to be 3/8th inch square drive, so check you have the right sockets for that.
    Some now offer a digital output.
  5. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,083
    723
    Screwfix
    Have a very good one and comes with extension bar.
  6. A3_130
    A3_130 Member
    85
    I bought a 3/8" drive torque wrench off Amazon for doing low torque bolts (it does 10-80Nm) so ideal for timing belt components, brake calliper guide pins , sump plug - that sort of thing. Was only £25 and I've been happy with it. You'll ideally want two torque wrenches to cover all the range of things on the car really (unless you spend big money on Britool or similar). I only have the small one as I'm worried about over-tightening and snapping things than under tightening big bolts.
