Torque Steer
Tj 0785 Aug 27, 2014
  1. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,545
    318
    I have a 2001 s3 I've had it about 3 months now but recently when the car is on boost the front wheels seem to wheel spin left and right or sometimes just to the left there's plenty of tred left on the tyres also I thought you wouldn't get torque steer on a awd?
  2. shan00ble
    shan00ble Member
    211
    I have 2001 s3 and I don't get any torque steer. Is your alignment set up correctly? Are your ball joints etc in good nick?
  3. <tuffty/>
    21,897
    4,206
    Is your haldex actually working... I have quite a bit of power and no torque steer at all...
    Front wheels should not spin if haldex is working
  4. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I never get torque steer in mine. The most ill get when pulling away is just a chirp from the front wheels.
  5. Tj 0785
    1,545
    318
    How could I check if the haldex is working? Il have a look at ball joints when get chance
  6. Prawn
    11,677
    3,676
    This might sound daft, but try and pull away aggressively on a slippery surface. You'll soon knownof the fronts are spinning up or if the rears are kicking in.
  7. Tj 0785
    1,545
    318
    Will try that in morning
  8. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    check the hadlex fuse too:thumbs up:
  9. Tj 0785
    1,545
    318
    Ha will do I'm never that lucky tho
  10. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    It will be the fuse...
  11. gabin
    gabin Member
    131
    12
    Put your car on an elevator,lift it a little bit and accelerate slowly. You will see if the haldex is working or not.
  12. Tj 0785
    1,545
    318
    So I checked the fuse that's fine and haldex seems to working so I think it's down to the **** £40 new tyres that was on the car when I got it they got a 30% rating for wet grip which could explain it
