Torque settings
domburg Dec 30, 2009
  1. domburg
    domburg Member
    89
    hi guys
    just rebuilding the top end on my 8l s3,its the APY engine, can anybody tell me the torque settings for the head bolts please? :readit:
    cheers, dom
  2. zeeeebo
    zeeeebo Lifes one big laugh
    416
    does it not say in haynes manual? pop down to halfords and have a sneeky peek at one!
  3. domburg
    domburg Member
    89
    yeah ill have whip down if i cant find them, my nearest halfords is about an hour 45mins way
  4. zeeeebo
    416
    where do you live!!!! im about 15miles or i would pop down and have a look for you! why dont you buy one off ebay as you might need it if your rebuilding the head!
  5. domburg
    domburg Member
    89
    cheers mate, i live out in the sticks near Hull and halfords is on the other side of hull so it can be a bit of a ball ache sometimes, i cant find an s3 haynes manual anywere, the a3 ones say that they dont cover the s3 or qauttro, should be ok without it but we arnt sure on the torque settings ill try and google it, just thought id give it a try on here first.
    cheers tho m8
  6. <tuffty/>
    21,008
    3,770
    http://forums.fourtitude.com/zerothread?id=3425946
    **EDIT**
    The above link suggests head bolts should be initially torqued to 60nm but others have said 40nm. I have looked in the A3 haynes manual I have and looked at both the AYP and AMK engined S3's in ElsaWin an both sources state 40nm. I am looking to confirm this information for my own sanity as I don't want to post misinformation. The above link is useful and I know others that have used it but 20nm difference is quite a bit.
  7. rossbrownlee
    rossbrownlee Ross_S4
    719
    head bolts torque for the 1999 apy engine is 40Nm, then 90deg turn, then another 90deg turn.
  8. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Thats corect ! You also start from the centre:
    10 4 2 6 8
    7 5 1 3 9 This end is the flywheel ans make
    shure you use NEW bolts !
  9. domburg
    domburg Member
    89
    thanks for that guys really appreciate it :beerchug:
  10. Matt82
    Matt82 Active Member
    2,365
    domburg, id try and find a copy of elsawin, or even just the extracts for putting the lump back together. id rely on that far more than a haynes
  11. rossbrownlee
    719
    :iagree:
    you don't need the latest rev either since your car is 10 yr old, APY just like mine!
