torque settings for fitting a3 tdi clutch please
welshd1k Jun 26, 2014
  1. welshd1k
    welshd1k Member
    150
    Does any one have the settings / torque figures for fitting a Audi a3 2.0 Tdi clutch and flywheel please got the car on axle stands out back waiting for delivery of my new clutch .
    Many thanks Chris. Aka d1k :)
  2. omblad0n
    omblad0n Member
    93
    13
    What year mate? I can have a look in elsawin if it has the values
  3. welshd1k
    welshd1k Member
    150
    2004 thanks
  4. omblad0n
    omblad0n Member
    93
    13
    the 170 hp version?
  5. welshd1k
    welshd1k Member
    150
    140 bkd
  6. omblad0n
    omblad0n Member
    93
    13
    Is this what you need?
  7. welshd1k
    welshd1k Member
    150
    Yep can't see the figures though
  8. omblad0n
    omblad0n Member
    93
    13
    Sorry, didnt realize u cant enlarge picture. Heres all the text in the picture:
    1 - Dual-mass flywheel
    q Removing and installing →Engine, mechanics; Rep. Gr.13
    q Ensure that dowel pins fit tightly
    q Contact surface for clutch lining must be free of grooves, oil and grease
    q Observe instructions for removal → Fig.
    2 - Clutch plate
    q Removing and installing → Chapter
    q Always renew pressure plate as well
    q Installation position → Fig.
    q For diameter of clutch plate, refer to → Electronic parts catalogue
    3 - Pressure plate
    q With adjustment mechanism
    q Identification → Fig.
    q Checking ends of diaphragm spring → Fig.
    q Checking spring connections and rivets → Fig.
    q Always renew clutch plate as well
    q For correct version, refer to → Electronic parts catalogue
    4 - Bolt
    q M6 - 13 Nm
    q M7 - 20 Nm
    q Loosen and tighten bolts consecutively in steps of 90°
  9. BatmansMate
    BatmansMate New Member
    12
    Omblad0n - did you get that figure from a book or a website.. Wouldn't mind having a look myself. Thanks
  10. omblad0n
    omblad0n Member
    93
    13
    Its a software called ElsaWin. Its made by Vag and used in garages. Covers all the Vag range. cost over £100 for a genuine copy. Or you can get a Bentley workshop manual for a bit less
