torque setting needed front hub nut
vr6gordy Aug 15, 2011
  1. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    anyone know what the torque setting is for a 2004 audi a4 1.8t cabriolet quattro front hub nut is please
  2. Rhencullen1989
    Rhencullen1989 190 S LINE QUATTRO
    97
    According to the good old haynes manual depends if your hub nut is 14mm thread or 16mm thread.
    M14 stage 1 115 NM (85 lbf/ft) then stage 2 angle tighten a furthur 180 degrees.
    M16 stage 1 200 NM (148 lbf/ft) then stage 2 angle tighten a furthur 180 degrees.
    These are when using a new stretch bolt, if using an old bolt you will find it hard to achieve these settings as the bolt will already be stretched. I tend to do them nice and tight using a breaker bar if i re-use the old bolt, although i strongly recommend using a new one.
  3. quattrojames
    14,060
    583
    If I've read it right from Elsawin:
    M14 115NM
    M16 200NM
    Plus half a turn when the wheels are back on.
  4. quattrojames
    14,060
    583
    Must be right then lol
  5. Rhencullen1989
    97
    Yep guess so!!!!!!!!!!!!:yes:
  6. T0m
    T0m Active Member
    516
    26
    Excuse me for acting dumb a hub nut? are you talking about the bolts that hold the wheel to the axle?
  7. quattrojames
    14,060
    583
    It's the bolt in the centre of the hub on the end of the drive shaft.
    T0m likes this.
