Torque setting for S3 flywheel+clutch HELP
mike-turbo Nov 7, 2009
  1. mike-turbo
    mike-turbo Member
    109
    Hello to you all,i'm after the torque setting for the dualmass flywheel and the clutch from a audi s3 03 reg 8l .
  2. mike-turbo
    mike-turbo Member
    109
    anybody know the torque setting?
  3. j4jon
    j4jon Member
    704
    The Haynes manual for the A3 (for 1.6, 1.8 and 1.8T) says:
    Flywheel/driveplate mounting bolts
    Stage 1 60NM
    Stage 2 Angle tighten a further 90 degrees
    I'd guess the figures would be the same for the S3?
  4. rossbrownlee
    rossbrownlee Ross_S4
    719
    Pressure plate to dual-mass flywheel:
    M6 - 13Nm
    M7 - 20Nm
    M8 - 22Nm
  5. rossbrownlee
    719
    Dual mass flywheel to /crankshaft:
    60Nm plus 90degree turn, use new bolts.
  6. mike-turbo
    mike-turbo Member
    109
    thank you lads for that now can put the car back together.
