Torque App - Boost Not Being Read
HamsterHam Oct 30, 2013
  1. Buzzer
    Buzzer Member
    410
    14
    Will it show boost aswell, not mentioned on the website.
  2. <tuffty/>
    21,950
    4,227
    There is a setting for Intake Manifold Pressure and a 'Turbo Boost & Vacuum Gauge' in Torque but never used it as I believe it would be using MAP sensor pressure so would be limited to 22psi...
  3. :: blade ::
    :: blade :: Active Member
    343
    31
    recieved my OBDII adaptor this morning and just been having a play, cant seem to find a boost gauge :S got one that said vaccum when i hit boost it changes over to boost but its going to about 28psi :eek: doesnt seem right that, also what should i have the boost calculation method on? MAP (default) MAF or ALT?
  4. CMcKenzie
    CMcKenzie It's supposed to do that..
    318
    127
    43
    Have you got the paid for version? No boost gauge on the free version.
  5. :: blade ::
    343
    31
    yep paid for it :),
  6. CMcKenzie
    318
    127
    43
    Paid version of the App?
    There should be Boost somewhere in the selection of gauges... :/
  7. :: blade ::
    343
    31
    yep paid version of the app, if i load the app up when its not connected in the car there is a boost gauge in with the 6 gauges, but when connected that changes to vacuum :S really confusing
  8. CMcKenzie
    318
    127
    43
    Hmm, try deleting it, then selecting it again, by pressing down on the screen, 'add display' select dial type, then add it again, that's all I can think to suggest. Stumped me that one mate.
  9. :: blade ::
    343
    31
    think ive sussed it :)
  10. CMcKenzie
    318
    127
    43
    What was up with it?
  11. :: blade ::
    343
    31
    me being stupid :)
    CMcKenzie likes this.
  12. :: blade ::
    343
    31
    going to the car now to plug it in see if it stays as boost :)
  13. :: blade ::
    343
    31
    nope still doing the same :'( vaccum then changes to boost when it kicks in, changed it to a differnt gauge and it boosts to about 12.7psi, but still not sure if thats on the right thing on the boost calculation
  14. jimmcgee
    jimmcgee Active Member
    273
    44
    the boost and vacuum are the same gauge , whats the problem ?
  15. :: blade ::
    343
    31
    Didnt want vacuum on it. was doing my head in. but sorted it. you can dusable it in the settings
  16. Freeman_1986
    Freeman_1986 Member
    169
    21
    I have the dash command app and Wi-Fi dongle. Cant get it to work though. connects fine, and can do the diagnostic readings and clear codes, but won't do anything else? any help?
  17. CazzaVR
    CazzaVR Member
    260
    15
    Just had a go with Dashcommand and the ELM wi fi dongle. Seems to be pretty much plug and play, although it doesn't seem to do boost and the bhp and torque seem a little optimistic. Says my car is 299bhp and 409lbs of torque! Anyone know if I need to adjust anything? I suspect the car has some sort of remap and only other mods are B5 v2 TIP and 007p.
  18. Freeman_1986
    Freeman_1986 Member
    169
    21
    There is boost on there, I've seen it. Just nothing happens when I plug it in? It has been remapped before. Would this stop it working?
  19. CazzaVR
    CazzaVR Member
    260
    15
    Yeah, mine has boost in the gauges, but nothing happens. Most of the other stuff seems to work.
  20. Freeman_1986
    Freeman_1986 Member
    169
    21
    Ahh misread. well at least some readings work on yours lol.
  21. Goubo1
    Goubo1 Well-Known Member
    958
    298
    Has anyone else used a tablet mounted like this ?? If so is it sturdy enough for some fast B road driving ??
  22. Swervedriver
    Swervedriver Member
    92
    Is there a windows phone version off the app? Or something similar for windows?
    Cheers guys.
  23. badger5
    9,631
    2,070
    torque pro app on tablet and obd split cable will read K6 outputs btw ~Rob..
    Goubo1 likes this.
  24. Goubo1
    958
    298
    That will be ideal then bill
