Torque App - Boost Not Being Read
HamsterHam Oct 30, 2013
  1. HamsterHam
    HamsterHam Member
    43
    Hi all,
    I have the torque app (Android) and an OBD2 bluetooth device however the Boost just stays on 0, says no reading available.
    Anyone else had this problem and resolved it?
    HamsterHam
  2. CMcKenzie
    CMcKenzie It's supposed to do that..
    317
    126
    43
    Hi there,
    what year and model is your car? I don't think the app works with the AGU code engine. Does it display any of the other units?
    eg. Intake temp, maf, revs and so on?
    I'm using it with a 2000 APY S3 with no issues, without a little bit of info on your car, it's hard to say.
    Callum.
  3. HamsterHam
    HamsterHam Member
    43
    Audi S3 1.8T 51 Plate. Revs work I know that much. Need to check the others. Do I need to change any settings?
  4. CMcKenzie
    317
    126
    43
    Hmm that's a weird one.
    The only setting I remember changing was in 'OBD2 Adapter Settings' and selected 'Faster communication'
    Other than that it was plug and play.
    The only thing I can suggest is try the website: Torque — OBD2 Performance and Diagnostics for your Vehicle and have a look in the wiki or ask on their forum.
    Hope you get it sorted soon mate, it's a handy little gadget to have. I even went and bought a 7" tablet to run it, just trying to figure out a way to mount it without blocking the whole windscreen.
    Best of luck,
    Callum.
  5. shariain
    shariain Well-Known Member
    1,182
    190
    I'm sure someone on here done an install with a tablet. They used the keys that remove the radio and the removal slots, then bent the end tabs that stick out down/up and bonded that to a case for the tablet. Now you have a tablet case with 4 locating pins that fits over the radio and is totally removable.
    Lavis89 likes this.
  6. HamsterHam
    HamsterHam Member
    43
    Do you have to setup a vehicle profile?
  7. CMcKenzie
    317
    126
    43
    I setup a profile yeah. I'll have a root around and see what I can find shariain, thanks for letting me know.
    Callum
    shariain likes this.
  8. chaz20vt
    chaz20vt Member
    428
    21
    Is this just a app you can download on Android though?
  9. jimmcgee
    jimmcgee Active Member
    263
    41
    you need to pay the full version to get boost , I use it on my a4 2003 all the time , handy app when your cruising down the motorway or stuck in traffic :readit:
    HamsterHam likes this.
  10. chaz20vt
    chaz20vt Member
    428
    21
    Where is the obd2 cable brought from
  11. jimmcgee
    263
    41
    Torque is a wireless bluetooth app , you need an obd2 bluetooth dongle to use it . although you can use a acable as well under andriod 4.1
  12. HamsterHam
    HamsterHam Member
    43
    Cheers. Works now!
  13. shariain
    1,182
    190
  14. CMcKenzie
    317
    126
    43
    Yeah I've been having a good look around, and that seems to be the best way, but I'm thinking of trying something like this I've seen for the TT
    So I can mount a windscreen suction mount onto it. Just trying to figure out how to fix it into my air vents. I've got a few pieces of aluminium I'm going to have a play around with and see what I can come up with.
    Callum.
  15. temp
    temp Member
    74
    This app sounds good had a look on eBay for a Bluetooth obd? Do you know if it would work with a s3 8l 1999 the ones I have looked at say 2001 onwards? And how much does the app cost?? Do you just go to app sort on your phone??
  16. CMcKenzie
    317
    126
    43
    This is the one I bought Super Mini OBD2 ELM327 V1.5 Bluetooth Car Scanner Android Torque Auto Scan Tool | eBay
    Nice and small so it doesn't get in your way if your OBDII port is down to the right of the steering wheel.
    The app only costs a few quid, and I've used it on mine a 2000 APY so it should work on yours too.
    Callum.
    Chris Jones likes this.
  17. CMcKenzie
    317
    126
    43
    Well, I've done it. This is the fruit of my labour this afternoon, a little 'pikey' but it does what I need it to do.
    Plus the tablet is 16GB with a memory card slot, so I can finally have my 40GB music collection with my at all times.
    Just need to run an in-car charger from the glove box, behind the centre console and out on the left hand side of the steering wheel.
    Callum.
  18. chaz20vt
    chaz20vt Member
    428
    21
    Don't think that looks to bad tbh
    Nice work
    CMcKenzie likes this.
  19. CMcKenzie
    317
    126
    43
    Cheers mate. I'm happy with it, that's all that really matters I guess.
    Callum.
  20. chaz20vt
    chaz20vt Member
    428
    21
    Was the holder from the bay?
  21. CMcKenzie
    317
    126
    43
  22. A4sportMrT
    A4sportMrT Member
    273
    23
    Can someone copy the link for the App from the AppStore.
  23. CMcKenzie
    317
    126
    43
  24. A4sportMrT
    A4sportMrT Member
    273
    23
    So this is only for android users?
  25. CMcKenzie
    317
    126
    43
    Yup.
  26. A4sportMrT
    A4sportMrT Member
    273
    23
    Bugger
  27. CMcKenzie
    317
    126
    43
    There is an app for iPhones, not sure of the name something like dash command I think. but you need a WiFi adaptor, not the Bluetooth one.
    Callum.
  28. A4sportMrT
    A4sportMrT Member
    273
    23
    Yeah i just found it.
  29. A4sportMrT
    A4sportMrT Member
    273
    23
    I have now got myself an new android phone. So will be downloading the pro version. Just need to get a holder for my phone and the bluetooth obd bit.
  30. sssline
    sssline Active Member
    134
    40
    Lol did you buy a new phone to be able to do this??
  31. <tuffty/>
    21,576
    4,048
    Cheaper than buying a jesus mobe, revs/dash commander and a wifi adaptor lol...
    sssline likes this.
  32. A4sportMrT
    A4sportMrT Member
    273
    23
    Definitely not, contract upgrade and was getting very annoyed with my iPhone 5
  33. :: blade ::
    :: blade :: Active Member
    343
    31
    just decided i shall be getting this :) and getting a vent mount for my crappy s2 so hopefully have it by the end of the week :D
  34. CMcKenzie
    317
    126
    43
    Be careful with the vent mount they can easily break the slats. That's why i made a mount for the suction cup to mount on to.
    Callum
    Edit: just realised that the s2 shouldn't be. Heavy enough to cause damage. But my tablet is.
  35. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Worth mentioning that I used Torque pro to log my gains from a basic stage 1 to a stage 2+ full custom setup.
    Logs were PERFECT from start to finish, and in my case the airflow /0.8 was within 1bhp of my output on R Techs rollers.
    Not the case for everyone, but this App does just read the same information the ECU does. It's good.
    Only for ME7 cars though.
  36. JimS3
    JimS3 Active Member
    736
    72
    Dash command app is an equivalent for Apple devices, but you need a wireless WIFI OBD2 sender, not Bluetooth.
    There are loads of skins to chose from:
  37. :: blade ::
    343
    31
    yea i found one that puts the weight of the phone on the dash not the slats so should be ok :) the part that fits in the slat is basically to stop it from falling forward :) will get a pic tomoz
  38. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Is this worth the £7 then? Plus the sender of course...
  39. <tuffty/>
    21,576
    4,048
    Torque works well...
    The wifi adaptors (recommended ones at least) are silly money... others can be had for 30 ish quid on eBay but no idea if they work... on Android the device needs to be rooted to allow a wifi device to work...
    The bluetooth adaptor is laggy but take it at face value... its better than no visibility at all.. :)
  40. JimS3
    JimS3 Active Member
    736
    72
    Think it was £4 when I downloaded it, definitely worth it. You can also make custom gauges, scales graphs etc, just like torque app.
    I ordered an ELM 327 Wifi sender off ebay, was £13 delivered. It has been working fine for several months, but it a bit of a faff to setup for the first time. It makes a virtual wireless network, but there are plenty of instructions online.
    When you compare it to the price of a liquid gauge etc, it seems a good value setup.
