Topping up engine oil on 1.8 quattro
Ryanytchan Mar 11, 2014
  1. Ryanytchan
    Ryanytchan Member
    150
    Hi all,
    As the title suggests I need to top up my engine oil-the dipstick showed around 1/3 full, which according to manual can be topped up. The dealer didn't give me a can to top up with and charges 15 quid for 1L so I'm just going to do it myself, is this the correct/best oil to use and will the funnel help at all? Also do I just top up 500ml at one go?
    http://www.amazon.co.uk/gp/product/...act_image_2?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
    http://www.amazon.co.uk/gp/product/...act_image_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
    As a side note-do you rotate tyres differently given it's a quattro, or do it as shown in manual?
    FYI owned car for 1 month and did 2000miles or so
    Cheers!
  2. s3 owner
    s3 owner New Member
    68
    I take it this was a new car? in which case using that much oil in 2000 miles sounds excessive. either that or the dealer didn't check the level before you picked it up.
  3. BigD289
    BigD289 Member
    104
    13
  4. RossR
    RossR Active Member
    501
    122
    43
    I've never known a new car be supplied without a bottle of oil for topping up. Have you checked behind the side panels in the boot?
  5. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,735
    1,630
    Yes mine came with 1l of oil...
  6. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,706
    1,522
    Just a point, if it was a third full you'd be having real problems, like other vehicles the dipstick doesn't reach to the bottom of the sump, you are a third of the way between minimum and maximum. Both ends of the scale are acceptable but it's best to keep it close to max.
  7. BigD289
    BigD289 Member
    104
    13
    Ours came with 1l of oil. It was in the boot with the spare. Maybe you should ask your dealer for one if you didn't get one?
  8. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    BigD289 is right. Get the EDGE long life that complies with Audi spec 504.00 regardless of whether you are on variable (long life) service or fixed service interval.
    Mobil, quantum etc also make equivalents.
    And no, I didn't get a bottle of oil with mine either.
    My 1.8 has hardly used any and I did a first oil & filter change at 3k miles.
    John.
  9. Diamond White
    Diamond White New Member
    26
    A bit cheaper here
  10. Ryanytchan
    Ryanytchan Member
    150
    Did you take the car back to the dealership for oil and filter change? Is a filter change needed at 3k miles?
