Topmounts : to poly bush or not to poly bush that is the question...
vrbob Oct 7, 2012
  1. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Thinking of changing my standard top mounts to poly ones as they are available form Creation Motorsport for about £39.
    They must be alot tougher than the rubber version and therefore less prone to wearing out and also offer a furthur 10mm drop at the front (which is something i want as my front is a little higher than the rear) and with this you get 10mm of extra dampening according to the blurb.
    POLYBUSH FRONT TOP MOUNT PAIR 44CF 2WD+4WDS, VW GOLF AUDI A3 TT,OCTAVIA LEON | eBay
    Any thoughts peeps?
  2. Squirrelofdoom
    Squirrelofdoom Member
    672
    23
    Do it and then tell me if I should :p What about the top mount bearings? Will these not load up the bearings more and cause them to fail faster?
  3. colicabcadam
    colicabcadam Guest
    you'll be suprised how unworn your current ones are ! i was when i saw mine !
  4. jojo
    28,856
    3,516
    New top mount on left, worn one after 13 years and 60k miles on the right.
    I'd go for standard topmounts with FK lowering caps personally, as the rubber topmounts gives some comfort to your ride. If you are running coilovers, I guess going poly wouldn't make much difference?
  5. dre_S3
    dre_S3 Member
    756
    39
    Jojo do they shrink that much :blink: when changed mine a few months ago they looked the same as that photo just thought they were different as I changed them for the Cupra r top mounts quite shocked in how much they have shrunk
  6. jojo
    28,856
    3,516
    They don't just shrink over time, just think the whole front end/weight is on top of those, so compressed aswell.
  7. dre_S3
    dre_S3 Member
    756
    39
    Yeah they do take a pounding mate and a lot of weight as you say
  8. vrbob
    2,375
    171
    Well gotta take mine off at some point anyway as need to replce one of the bearings as i couldnt undo the nut on the shock so think i will give them a whirl and see what they are like.
    Not running coilovers just uprated shocks and springs so the extra 10mm lower at the front will help my stance a little too.
    As the rest of thed car is polybushed it almost seems rude not too lol
  9. harvey01
    harvey01 Member
    523
    9
    hi all i put psi tuning polybush ones on last week there spot on but get some polo 6n caps
  10. karl210
    karl210 Member
    324
    i bet if youve got worn compressed ones like that then you probably wont notice the 10mm shorter ones, but if you put new standard ones back in the front end will probably lift up slightly
  11. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    If you are going to do this and haven't got a VAG top mount tool then I would really suggest getting one, I've pissed about with top mounts for years and it's always been a pain until I got one of these. Tool 3078 I think.
  12. Squirrelofdoom
    672
    23
    I always just used a windy gun to get the nuts off...easy
  13. jojo
    28,856
    3,516
  14. Sam_
    Sam_ Down under
    3,037
    480
    I've just got some ground control camber top mounts as the rubber ones don't seem to last long with coilovers. I imagine it'll be a wee bit firmer :)
  15. 16Klappe
    5,795
    1,184
    I don't have an air gun at home, wish I did though.
  16. jojo
    28,856
    3,516
    Neither do I, I have an electric cordless one though. ;)
  17. 16Klappe
    5,795
    1,184
    I can't afford one. I spend all my money on go faster bits.
  18. Jason.s
    Jason.s Active Member
    2,879
    348
    Techically an electric impact gun is a go faster bit compared to a ratchet and allen key :p
  19. 16Klappe
    5,795
    1,184
    **** it, I'm going to buy one.
  20. harvey01
    harvey01 Member
    523
    9
    7mm allen key down a spark plug socket spanner on the socket job done
  21. Grazam
    Grazam Member
    190
    i bought some poly top mounts never got round to fitting if anyone is after any i got some spares if you want. just text me
    07590437004 im in dorset as well id rather do collection can't be botherd with posting id even help fit them if you ask nicely
  22. niallh
    niallh Member VCDS Map User
    213
    I have polybushed the top mounts in my car, personally I cant say that much of a difference is made. As mentioned before you definitely need to buy 6N polo top caps
    I couldnt afford a cordless one so i bought this Clarke CEW1000 Electric Impact Wrench - Machine Mart
    I rate it very highly not struggled with anything i have put it through which included fitting coilovers, these top mounts and polybushing the rear beam
  23. Dani_B19
    9,167
    362
    Hasnt their been a right up on these already? Not sure if it was on here or not, ill try to find it but im sure the poly top mounts got slated, something about noise and aomething else. Ill try to find it.
  24. vrbob
    2,375
    171
    Well have oredered a set of the CM ones so will report back when i get round to fitting them.
  25. Squirrelofdoom
    672
    23
    good stuff, let us know :)
  26. vrbob
    2,375
    171
    Top Mounts arrived this morning, i also took the plunge and bought a dirt cheap electric impact wrench off ebay to make undoing the nuts easier and also mto help with wheel changes.
    I got this Liftmaster 12V Impact Wrench with Digital Display & Torque Configuration | eBay
    Had a go on my wheel nuts and they come off easy and also tried it on the top not that hold the capon the strut and that came off too so seems like it will do the job. plus i can now set the torque using its in built gauge.
  27. Squirrelofdoom
    672
    23
    lol, that impact wrench looks like a proper cheapo ebay jobbie :) hope it holds up for you! let us know how you get on. Did you end up getting different top caps?
  28. vrbob
    2,375
    171
    Yup its cheap but seems to work and for what i need it for it should do the job. It is rated to 350nm which was alot more than some of the more expensive ones.
    Nope didnt buy new top caps yet gonna fit the mounts first and then see how high the old top caps sit after.
  29. 16Klappe
    5,795
    1,184
    I wouldn't trust the gauge, just make sure you manually check them after.
    Good luck, I loom forward to seeing a review :)
  30. vrbob
    2,375
    171
    Nah the gauge probably isnt accurate but it does seem to work cos if i set it to say 150nm and do up a wheel nut you can see the torque going up on the gauge and then it stops when it reaches 150 and says end so at least it gives me a way of making sure i dont overtighten stuff.
    Got my catch can setup to do first once the pipe i ordered shows up as i need to borrow a friends spring compressors to do the top mount job properly.
  31. 16Klappe
    5,795
    1,184
  32. vrbob
    2,375
    171
    been reading the catch can guide in the stickies as the guide you posted is the same as the one westy used when writing his.
    Just gotta work out the differences as mine is a BAM engine so not exactlky the same as i dont have SAI etc.
    I have already mounted my Catch Can i got a cheap and chererful one off ebay and have mounted it to to my heatshield (s3dave`s) as it looks nice and neat. Also means i need alot less pipework running about as i cn turn the hockey puck 45degrees and jooin it to one outlet and then run the other outlet to a t peice that then goes back to the block and down to the oil filter.
    Am sure i have to block off the nipple under the inlet manifold but there is something else to the left of the inlet manifold near where the DV nipple that i also have to do something with but cant remember what exactly.
  33. vrbob
    2,375
    171
    Did my catch can install today and am pretty pleased with the results. Had a minor mishap as the 90 degree bend that comes out of the oil filter housing decided to disintegrate as I tried to remove it. So had a quick call around and TPS had one on the shelf so £30 later I have a new one. All connected back up and new pipes routed and car runs really nice and idle is rock solid. Another job done :)
  34. Squirrelofdoom
    672
    23
    nicely done. i'll take a look at your install when I get down there
  35. vrbob
    2,375
    171
    Sounds good mate :)
  36. vrbob
    2,375
    171
    Couple of quick pics of my latest mod my catch can install......
    All seems good, May look at venting to atmos at some poiont soon too as i am thinking or running a pipe to the hole in the passenger side wing where the old feed for the airbox used to be.
  37. ReDBull
    ReDBull Member
    217
    13
    I'll be interested in what you think of the top mounts as I've got them to fit. Catch can looks neat that's on my to do list as well.
  38. vrbob
    2,375
    171
    Topmounts are the next job but waiting on a second pair of hands as almost lost a finger doing it before lol.
    Yeah am pleased with my Catch Can setup it was cheap and cheerful but seems to be doing the job and looks good where tis located without too much pipework etc.
  39. Dani_B19
    9,167
    362
  40. vrbob
    2,375
    171
    Linky does not seem to work mate.
    My mate is already running the PSI poly topmounts on his S3 and so far he is pleased with the results so would like to see any more info as such.
