Top Up Oil Spec 2.0TDi
Gti Jazz Blue Mar 26, 2007
  1. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    I need to get myself some LongLife Topup oil for the 2.0TDi. So what spec and best place to pick it up ?
    Cheers,
    Paul
  2. Amchlolor
    Amchlolor Active Member
    5,604
    Spec is one of the following,which is displayed on the Miller Oils drum we have here
    VW503.00
    VW506.00
    VW506.01
    I have a feeling 506.00 is the longlife one.
  3. shaheed
    shaheed Member
    65
    505.01 Semi-Synthetic (normal plan)
    506.01 Long-Life
    507.00 (new generation for Long-Life. From Audi dealer the only one available in future for Long-Life)
  4. tommac
    tommac New Member
    19
    so which brand does everyone recommend? castrol edge 0w30 TD?
  5. h5djr
    9,397
    1,734
    For a 2.0TDI-140 the correct top-up was VW 506.01 with AVS and VW 505.01 for fixed interval servicing. Both of these specifications have been superseded by VW 507.00. 507 is also the only oil that should be used in a 170 2.0TDI.
    Both Castrol Edge 5w-30 and Shell Helix Ultra VX 5w-30 meet the 507.00 specification. Others may also meet the spec but check on the container. If they meet the spec they will say so I'm sure.
  6. Amchlolor
    5,604
  7. ScottTDI
    ScottTDI Member
    84
    10
    You could try Opie oils (on ebay), they sell Castrol longlife or Fuchs Titan GT1
    5w-30 vw507 spec(I'm told this is whats used from the factory).
    I bought some the other week,its reasonable priced,free delivery and quick service.
  8. emzino
    emzino Active Member
    1,231
    Here's the bottle of Castrol I have in the boot in the small Audi bag:
    Does that means it's on AVS? (Btw, is AVS another term for Long-Life servicing?)
  9. h5djr
    9,397
    1,734
    Yes Longlife Service and AVS (Audi Variable Servicing) are the same thing. I think all new Audis leave the factory set for AVS. To check - look at the sticker with the VIN number in your service book. In the 3 digit codes in the lower part of the sticker should be one 'QG1'. This means Service Interval Prolongation in Audi speak which means Longlife Service of AVS.
  10. tommac
    tommac New Member
    19
    thanks for that guys will get some castrol edge 5w30 later today!
  11. Gti Jazz Blue
    1,655
    Ouch £13.99 for a Litre of Castrol Edge at Halfords. I used to pay that for 5 Litres of Semi that I used in my Mark IV Golf (changed every 5K though).
    I hope my 2.0TDi doesn't used too much between changes.
    Thats everyone for your help.
    Paul
  12. Amchlolor
    5,604
    That's the reason we (the company) went for a 25L drum of Millers.
    All bar one of our 2.0 tdi's burn oil at the sort of rate a 1972 Maxi would be proud of,so the MD got fed up of paying £15 per litre from the local Audi dealer.
    So he set someone the task of finding an alternative.
    The Millers works out at just under £10 a litre.
  13. Gti Jazz Blue
    1,655
    Comming from a 120K Miles 1.8T that didn't need touching between 5K changes this may well be a bit of a shock.
    I guess my Shell Plus points will be getting used on Shell Helix of the correct spec.
    Paul
  14. Amchlolor
    5,604
    You might strike it lucky and get one that doesn't use any.
    It does seem to be a bit of a lottery though.
