Top mount replacement help.
Danman1 May 23, 2012
  1. Danman1
    Danman1 Thorough noob
    342
    19
    I am about to replace my front top mounts on my 2002 S3. I've searched and read some threads (including Tufftys) on this but was wondering if someone could spell out how the front suspension strut is removed/direct me to a guide.
    What tools are needed and what parts. I already have the rubber mounts with new bearings do I need anything else?
    Dan
  2. Dani_B19
    9,320
    389
    Just to add a questions, can this be done with the damper in situ? Ive got collies and want to inspect my top mounts but cant be ***** remocing the entire set up?
  3. pj123
    pj123 Member
    307
    13
    I'm planning to do mine this weekend. Would also like to know if you could use spring compressors and avoid disconnecting the lower suspension. Will tracking need redoing?
    I just have a rubber top mount and bearing for each side. Pair of spring compressors are the only specific tool i have.
    A guide here Noah's MkIV VW H&R Coilover Installation HOWTO
  4. <tuffty/>
    21,355
    3,922
    Need to remove the strut Dani...
    You ideally need a special tool to spread the hub to get the strut out and spring compressors if not coil overs...
    This guide will help but you do NOT need to drop/undo the subframe to do it like is suggested...
    MKIV Jetta Suspension Installation
  5. Dani_B19
    9,320
    389
    Aww thats poo. Fmic in the sun it is :) haha.
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You can change them without removing the strut IF you have coilovers...plenty of room just drop the ARB link..:)
  7. Dani_B19
    9,320
    389
    Ill look into if i get chance, thanks for the heads up dave.
