Top mount problem (with pics)
milli Aug 30, 2012
  1. milli
    milli Member
    179
    9
    Hi all, changed my suspension to weitec coilovers on saturday and also changed top mounts for standard ones. Problem i have, opened the bonnet to find this...
    When the car is jacked up on the front they sit how they should, but as soon as i lower the car back down this is the problem.
    Do i have a bad problem or have i changed something wrong, if anyone can shed some light would be gratefull.
  2. Dani_B19
    9,046
    336
    The car in level ground? You tightened everything up properly? Also have you fitted the top mounts and bearings properly?
  3. dancupra225
    dancupra225 Active Member
    667
    25
    bet the bearing is wrong way round
  4. Greg-S3
    Greg-S3 Active Member
    529
    49
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Mount,upsidedown...
  6. Tooks
    Tooks Active Member
    753
    29
  7. Greg-S3
    529
    49
    It must be your top mounts mate, not much else can be at fault!
  8. Squirrelofdoom
    Squirrelofdoom Member
    671
    23
    hmmm, mine are like that after replacement, but not really as bad - I think I put all mine back in the right way round... :S
  9. milli
    milli Member
    179
    9
    has any body got any pictures of the front suspension set up with the mounts on so i can make sure they are the right way round?
  10. jojo
    28,831
    3,485
    They should be this way up.
  11. Squirrelofdoom
    671
    23
    what about the bearing? That sits in the top yes? And that should only go one way up?
  12. milli
    milli Member
    179
    9
    im sure thats the way i put them ontop of the shock
  13. knoxie
    knoxie K4OXE
    619
    15
    sorry this is no help to the op but im doing my top mounts this weekend and do you need spring compresssors/clamps?
  14. s3dave
    10,110
    736
  15. milli
    milli Member
    179
    9
    trying to look at that picture, just not sure which part is which. From what i remember from top to bottom i have plastic cover, nut, cup thing, bolt on top of coilover, bearing, then spring i think
  16. s3dave
    10,110
    736
  17. jojo
    28,831
    3,485
    The bearings looks like this(pic below), usinfg the white new one as an example, the white bit should be facing downwards, then the top mount goes on top of it.
  18. Squirrelofdoom
    671
    23
    damn...i think i've put mine on the wrong way. I think i but the bearing on top of the top mount :S Guess i'll be buying 2 new bearings and re-doing it. Just got the bloody car tracked today as well :S
  19. jojo
    28,831
    3,485
    That would explain why they are sticking out so much then!
  20. milli
    milli Member
    179
    9
    Update! Been working on the car tonight, pretty much just finished. Took the front struts back off and re built, this time had the bearing, new top mount then bolted together, fitted the top cup and bolt and they sit slightly lower then before still has about 3-4mm gap between though.
  21. Dani_B19
    9,046
    336
    Yeah its normal to have a small gap mate. Sounds like youve sorted it now though.
  22. milli
    milli Member
    179
    9
    From one problem to another, after finishing the car, now my ABS and EML light are staying on, i took the wheels off again and checked all plugs and they all seem to be fine? Any ideas or am i best of getting it scanned?
  23. Scoot123
    Scoot123 New Member
    25
    Have you taken it or a run ? They should go off after a drive.
  24. Squirrelofdoom
    671
    23
    mine stayed on before i got mine re-tracked and indeed after i got it re-tracked for about 30 miles and a couple key off/ons
  25. milli
    milli Member
    179
    9
    Been out a few times and the lights are still on, waiting to fit my adjustable tie arms, then getting 4 wheel alignment done, so hopefully after that they should go off....?
  26. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Don't understand why they should come on in the first place if only changing top mounts...?
  27. Squirrelofdoom
    671
    23
    Gonna dd my 2 pennies now. Looked at my installation of the top monts and I think I've done them all the right way. Took off the two nuts on the top and the bearing is obviously BELOW the top mount, so seems to have been done correctly.
    Only think I'm concerned about is that the shocks seem to be sitting quite off-center of the mounts (visible in the pictures below); is this normal?
    Cheers,
    Aran
  28. BuuBBa
    BuuBBa Member
    133
    Just fitted my PSI PU top mounts and **** those creak when turning :sob:
    I was expecting that but somehow hoping that "not for me"...
    What is the torque for the nut over the strut cap? I was thinking (or hoping) that if that is too tight or loose it could cause that creaking..
  29. knoxie
    knoxie K4OXE
    619
    15
    anyone :(
  30. jojo
    28,831
    3,485
    YES.
  31. knoxie
    knoxie K4OXE
    619
    15
    thanks mate :)
  32. jojo
    28,831
    3,485
