top end flat spot/hesitation BAM
ttseph Jun 26, 2013
  1. ttseph
    ttseph New Member
    19
    Hi iv got a bam 225 engine with a problem, ive not long had it so im pretty clueless as to what the problem is....
    It runs what seems alrite up to about 5-5.5k revs then feels as though its stuck/somethings restricting it which aint the limiter, as it hesitates/fluctuates for a few seconds then pings past it to the redline at 7kish.
    people have suggested boost leaks, overboost, coil packs, dump valve etc.
    ive checked pipes over and over, replaced the inlet pipe, n75 valve. the problem is still there.
    any pointers please and oh yeh no engine light is present.....
    abs/esp light randomly comes on and ! with a circle round it in red in the middle dash panel, turn the car on and off and it will dissapear? not sure if thats anything to do with it but just read a post about a dodgy MAF pulling that light up so thought id mention it.
    cheers for any help.
    seph
  2. ttseph
    ttseph New Member
    19
    forgot to mention when i let off the throttle to change gear it revs a little extra as if im still giving it a bit of throttle???
  3. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    hi newbie, first posts as always a problem lol... get an obd 2 cable off ebay and the free software from ross-tech.com then plug your laptop in, bingo your car tells you whats wrong!-) cost you about 8 quid.
    SamHendry likes this.
  4. shariain
    shariain Well-Known Member
    1,182
    190
    Clutch pedal switch
    Causes car to over rev when the clutch pedal is depressed
    I took this from a sticky in the 8L section have a search lots of great info in the stickies.
  5. ttseph
    ttseph New Member
    19
    I'm getting it plugged in today but the is no engine light showing so not sure it's going to show up a lot
  6. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    There are hundreds of possible faults that will not throw up a warning light on your dash mate.... as well as leaking pipes.
    Where about are you located fella? You getting a VAG specialist to check it over for you?
  7. Nilz
    11,331
    881
    Could be a number of things, sounds like a similar prob to what I am having.
    The over revvnig between gear changes will be the clutch switch that will need replacing, I had to do mine recently when my clutch pedal snapped!!
    With regards to boost leaks, they are not always visible, if possible, get a smoke test or boost leak test done on the car which will help to identify the issue some more for you.
  8. ttseph
    ttseph New Member
    19
    Cheers for your replies, iv had it plugged in, wiped all previous codes and the code that came back up is....
    16705 po321 ignition/distributor or engine speed input circuit-g28:range/pperformance
    which given the lack of top end power I'm assuming will be a coil pack?? If anyone can clarify before I shed out on new coil packs would be a great help
  9. StaceyS3
    StaceyS3 Well-Known Member
    2,502
    491
    Seph is popping round later and will be having a look over his car, ive got a spare engine speed sensor or 2 but have had AGU's and a APY blocks that have broken and not sure what come from which
    Can anyone shed some light to wether these are different between engine codes?
    Forgot to say his is a BAM
  10. StaceyS3
    2,502
    491
    Forgot to say i would check ETKA or look at the sensors but theyre at work and was hoping soneone coukd confirm before I get a lift or cycle (because im lazy like that lol) ;)
  11. Westy
    Westy Well-Known Member
    17,443
    1,103
    I've swapped AEB and BAM cam position sensors without any issues so you might be ok. I'm sure that part was the same number too.
  12. ttseph
    ttseph New Member
    19
    Swapped the crank sensor over fine cheers Stacey, still got the same code coming up tho, cam sensor maby?
  13. Gops
    3,198
    666
    Possible Symptoms
    Engine shuts off
    Engine doesn't start
    Speedometer inoperative
    Glow Plug Indicator Lamp (K29) flashes
    Possible Causes
    Engine Speed Sensor (G28) loose
    Engine Speed Sensor (G28) faulty
    Possible Solutions
    Check Engine Speed Sensor (G28)
    Special Notes
    The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
    When an engine will not start due to mechanical timing or spark/fuel related issues it is not uncommon to set G28/G40/G163 fault codes. The basics should be checked if this code returns after extended craning and a no-start with a new sensor installed.
    When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro magnetic interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
    When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation.
  14. ttseph
    ttseph New Member
    19
    Thank you very much, have now changed cam and crank sensor. But it is still got hesitation at the top of the rev range and sometimes randomly. I noticed today it does not do it when it's cold!? It has a aftermarket cone filter on with no proper cold air feed, could the hot air cause this problem does anyone know? The engine seems too hot when opening the bonnet after driving but still reads 90 in the gauge.
  15. HansfishS3
    HansfishS3 Active Member
    507
    67
    Intake air temperatures? Over 55C ECU will hold back
  16. S3AMJ
    S3AMJ OEM+ Audi S3 Team Brilliant Black
    371
    77
    Dude this thread is over 2 years old
  17. badger5
    9,471
    1,988
    it starts pulling timing from just 39'c aits std
  18. HansfishS3
    507
    67
    Oh really? So my loss of power at 40C IAT makes sense, do you know how the timings are scaled with temperature?
  19. SamHendry
    SamHendry Active Member
    542
    100
    43
    Seph did you get it sorted?
