Tool to remove Airbag light. Cheap eBay one?
_Alex_D_ Apr 19, 2014
  1. _Alex_D_
    _Alex_D_ Member
    126
    Please don't say vcds cause not got laptop. I've got torque and a bluetooth thing but doesn't do airbag
  2. jay1601
    jay1601 Well-Known Member
    1,347
    73
    voorhees likes this.
  3. JimS3
    JimS3 Active Member
    736
    72
    Are you just trying to reset a fault code, or are you trying to disable an airbag or hide a problem with the system?
  4. _Alex_D_
    _Alex_D_ Member
    126
    Just reset fault code. Only comes up if seats have been moved
  5. JimS3
    JimS3 Active Member
    736
    72
    There are some hand held scan tools that reset air bags, as in the link above. However I have seen a cheap one of these cause the air bags to fire on a vw bora while trying to reset the codes.
    Best to reset it with VCDS or a Snapon Solas etc. If you haven't got a laptop many independent garages will do it for very little.
  6. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,246
    2,071
  7. _Alex_D_
    _Alex_D_ Member
    126
    Garage near work can so it. Had it reset three times by them now. If I put seats forward to let someone in back with ignition on it tends to come on (Airbag light). Was just thinking cheap tool would be easier than pestering garage every five minutes.
    Only had 6 months. Mg motors in ripley got full vcds by the way
  8. voorhees
    16,246
    2,071
    Has to be a loose connection,are the connectors in the metal frames ?
  9. sportquattro
    sportquattro Active Member
    845
    51
    Call me daft but clearly your car has a fault with its airbag system, and given its a pretty important safety issue would it not be better top sort the root cause of the problem rather than just resetting the light, if the worst does happen and you have a prang then to my mind I'd be wanting a 100% serviceable system with no faults that might prevent the airbags going off.
  10. hades-
    9,482
    646
    the wires need sorting under seat
    its either unplug clean and refit.
    or
    cut plugs off and rewire then you wont have the light on again.
    very common
  11. _Alex_D_
    _Alex_D_ Member
    126
    Ok. Was taking lazy root lol
  12. VAG-Slag
    VAG-Slag Well-Known Member
    1,772
    409
    if you just want to reset the ECU disconnect the battery for a half hour or so...
  13. _Alex_D_
    _Alex_D_ Member
    126
    Will that clear fault. Was just looking at maxiscan 300 b y autel. £15
  14. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    If your local pop round and ill reset it, cant see your location though just going on voorhees post
