Too low for the sump!
John-H Mar 15, 2011
  1. John-H
    John-H Member
    35
    I hit a raised manhole in a council roadworks section in Trafford Park today in my S3. The car is bog standard height but that's a little low to start with - it might serve as a warning to what can happen.
    The council have been resurfacing the road and have removed the top surface of tarmac. There was a sign saying "RAMP" but there was no sign saying "raised manholes" - consequently I was expecting the up ramp at the crossroads but not the raised manhole 20 feet before it, which I went over dead centre only seeing it at the last moment because of a car in front, with a left turning car on my left and bollards on my right I could go nowhere - BANG!
    I then bumped up over the ramp at the crossroad as expected with no problem but as I got to the other side the following cloud of oil smoke, which didn't go away as a splashed puddle might have, told a different story!
    Engine smartly turned off I coasted to a halt and getting out I could see the oil slick so pushed it round the corner and waited for recovery.
    To cut a long story short, it's at Awesome GTI: about £50 for an aftermarket sump (the original had a hole I could get two fingers in!), but with oil, filter, gaskets, sealant and checks comes to £227, then there's the dog mount ripped out of the gearbox casting - that's an estimated £200 for alloy welding (luckily the casing is not holed), then there's the cross brace captive nut ripped out of the subframe. They have a second hand sub frame but with fitting and geo that will add another £400 ... Perhaps I can fix that later in a different way but even so ....
    My insurance legal cover say that with no signs saying "raised manholes" and with one clearly high enough to strike a car without being adequately cautioned, ramped or coned off and given that the council were in control of the area so can't claim they didn't know about it - and given that I've taken plenty of pictures and videos of other cars clouting the manhole, then I have a good case.
    I think it's one of life's unfair moments; given that I generally advise people against lowering due to the chance of hitting a speed bump or pot hole. I suppose some may laugh and even I can see the irony - but then again perhaps it may serve as a warning for what may happen!
    The sump is now replaced and the engine runs seemingly as before so hopefully the bearings and turbo are OK. I did turn the engine off perhaps 5 or 10 seconds after the bang when it dawned on me what was going on and I had knocked it into neutral, but the oil pressure warning light does not come on immediately on the 1.8T - the switch operates at 1.4 bar and at idle with hot oil you may only get 1 bar so whether the light comes on or not depends on what the software decides is happening! Give me a live swithch any day! Just waiting on the alloy welding now.
    A rogues gallery:
    Entering roadwork zone...
    Here's a car turning right (when rush hour had died down a bit)
    Allowing him to swerve to the left - but what for?
    The sump planer! This car clunked it...
    Even the 4x4s were slowing down for it - ok if you could see it in time.
    I'm not the first to hit it.
    If you look carefully at this one you can see the leading corner of the cast iron manhole and the lack of adequate ramp before hand.
    And the resultant oil slick:
    And this is what it did:
  2. Dani_B19
    9,382
    403
    **** me, that is just bad bad luck, think i may invest in a reinforced sump now though :/.
  3. warrenlord
    warrenlord Member
    771
    15
    unlucky, make sure the council pay for it, defo wont be going down there for abit. they have been doing the same around my area and i wont even go near it as i know when i see that ramp sign that the floor is dropped down and all the man covers are raised like you said.
  4. S3KO4
    S3KO4 Member
    850
    God I feel your pain, you could have done the job yourself! I would sue the council and and take some sort of a proof from Awsome GTI, hopefully they can pay you back or something. hopeyfuly the damage has not affected the engine itself.
  5. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    No sign for "raised ironworks" that's non compliant with Chapter 8. Send the bill for repairs to your local authority, they'll wriggle and claim they aren't liable but keep being a pain and they should pay up. Had similar happen to the lower crossmember on my old XR2i
  6. S3KO4
    S3KO4 Member
    850
    Also try using the Iphone App 'Fill That Hole' they have a website thier special websites which supports people like yourself
  7. finesse
    finesse Active Member
    2,805
