Today's task.... Vent pod boost gauge
Craig Cull Apr 5, 2014
  1. Craig Cull
    Craig Cull Well-Known Member
    2,311
    1,106
    Well, I've never fitted one of these before so it could go one way or the other.
    It looks fairly self explanatory but that doesn't mean a lot lol!
    I will post this afternoon with finished results! 😜
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    I just use torque ap on my phone you can have multiple gauges as well,i have a really good screen mount.
  3. hades-
    9,481
    646
    this one ?
    simple to fit have you got the part to connect the pipework up ?
    i powered mine to the vent lights so they dimmed lit etc with normal lighting
  4. Craig Cull
    2,311
    1,106
    Yeah came as a full kit, I just wired it to the lights so it lights up at the same time as the dash lighting. Also the same colour as the dash lights. Definitely worth having.
  5. Craig Cull
    2,311
    1,106
    Didn't know they were very accurate, from what I've been told. I'll try it see how it compares :)
  6. Craig Cull
    2,311
    1,106
    While your here bez, it doesn't seem to hold boost, it's not the Intercooler or anything related. Still goes like stink like, do you think the waste gate could be blowing open slightly? Gonna do some logs and have a play tomorrow, what do you think?
  7. lynallbel
    lynallbel Active Member
    395
    Craig how come its showing a vacuum?
  8. Craig Cull
    2,311
    1,106
    Ignition wasn't on mate
  9. lynallbel
    395
    I didnt realise it an electric gauge, in my mind it was the capilliary version.
  10. Craig Cull
    2,311
    1,106
    It's got the electric sender, but doesn't do a thing until the engine is running or the ignition is on.
  11. Craig Cull
    2,311
    1,106
    jdp1962 likes this.
  12. hades-
    9,481
    646
    the needle should be at 0 when engine off
    i think you have a dodgey one.
  13. hades-
    9,481
    646
    whets it sit at when engine running ?
  14. Craig Cull
    2,311
    1,106
    According to the instructions it should be at 20hg + 10 in vacuum on idle, which it is. It sits at zero when the ignition is on.
  15. Craig Cull
    2,311
    1,106
    Ignition on -
    Ignition on with engine running -
  16. Craig Cull
    2,311
    1,106
    I realised what I've done. I just flicked the lights in to take a picture, but I didn't have the ignition on. That's why it wasn't showing anything on the gauge. Does it look right from the pics above?
  17. D2NY G
    D2NY G Well-Known Member
    1,088
    132
    that looks spot on fella, they easy to fit wunt mind one in mine
    Craig Cull likes this.
  18. Craig Cull
    2,311
    1,106
    Cheers bud, yeah it was fault straight forward, just need som plastic trim removal tools so you don't mark the dash. The rest is fairly straight forward. Only issue I had was getting the vacuum hose through the bulk head. The American instructions show a grommet, which is on the wrong side on our cars. So I just nipped it in through the rubber wiring loom cover, then under the ECU, jobs a good one :)
    Big Al and D2NY G like this.
  19. bigmoylan
    bigmoylan Member
    45
    Sorry for the thread revival, I was just looking at these and wondered if it would fit in the drivers side vent between the steering wheel and the door?
  20. Craig Cull
    2,311
    1,106
    Afraid not mate. The vent is designed for the left vent next to the steering wheel, as a direct fit. I suppose you could probably make it fit, but I wouldn't like to try.
  21. sabaxter
    sabaxter Active Member
    465
    27
    Do you have a link from where you purchased this gauge?
  22. bigmoylan
    bigmoylan Member
    45
    Thanks for the info, bit disappointing but what can you do, have you had any trouble from it with the heaters blowing hot??
    They're on awesome Gti mate. £110 plus postage for a full kit.
  23. Craig Cull
    2,311
    1,106
    Had no problems at all, but then again I don't really use the vents for heat.
    You can also buy them from psi tuning for a similar price for he full kit. That's where I got mine from.
