Todays problem - Front ABS sensor replacement
wysiwyg Oct 30, 2012
  1. wysiwyg
    wysiwyg Member
    So in fitting a control arm had to remove the whole damn hub assembly to drill the pinch bolt out. Couldnt get the ABS sensor out, smashed it up trying to get it out from the inside, so had to cut it off.
    Replace with used genuine or new pattern part?
    Mines an early facelift avant, would this fit, hes not a million miles away. VW PASSAT B5 SALON 2001 2.0 FRONT ABS SENSOR | eBay
    Cheers.
  2. aragorn
    18,484
    855
    There are new ones on ebay for about 15quid, i'm using a pair of them on mine and they're fine.
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    i just bought two from GSF for £25 posted
