S3_Olly
Full Throttle
- Joined
- Jul 22, 2011
- Messages
- 253
- Reaction score
- 0
- Points
- 16
- Location
- Aston, Sheffield
- Website
- plus.google.com
Hi All,
been having a few problems with the car recently so I thought I would give it a quick scan and this is what came up and the measuring blocks too -
17:02:49 Group 032
0.6 % Lambda
0.0 % Lambda
Bin. Bits
Bin. Bits
17:00:41 Group 115
720 /min RPM
15.8 % Load
1000.0 mbar Absolute Pres.
17:08:03 Group 002
720 /min RPM
15.8 % Load
1.70 ms Inj. On Time
2.17 g/s Mass Flow
17:08:57 Group 001
720 /min RPM
96.0°C Temperature
-3.9 % Lambda
00111111 Bin. Bits
17:11:13 Group 031
0.977 Lambda Factor
0.992 Lambda Factor
Bin. Bits
Bin. Bits
TID 01 - Rich to lean sensor threshold voltage Test:0.605 V
TID 02 - Lean to rich sensor threshold voltage Test:0.605 V
TID 03 - Low sensor voltage for switch time calculation N/A
TID 04 - High sensor voltage for switch time calculation N/A
TID 05 - Rich to lean sensor switch time N/A
TID 06 - Lean to rich sensor switch time N/A
TID 07 - Minimum sensor voltage for test cycle Test:0.190 V - Min:0.000 V - Max:0.595 V
TID 08 - Maximum sensor voltage for test cycle Test:0.670 V - Min:0.615 V - Max:1.000 V
TID 09 - Time between sensor transitions N/A
TID 10 - Sensor period N/A
Mode 01 - PID 01 : Readiness -- Address 10
Number of DTCs stored: 2 -- MIL Status: MIL ON
Misfire monitoring: Passed
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Failed or Incomplete
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Failed or Incomplete
Oxygen sensor heater monitoring: Passed
Exhaust Gas Recirculation: Not installed.
Freeze Frame Data for address 10
PID02 DTC that caused freeze frame data storage: P0030
PID03 Fuel system 1/2 status: Open loop, conditions for closed loop not yet satisfied
PID04 Calculated load value: 1.6 %
PID05 Engine coolant temperature: 60 °C
PID06 Short Term Trim - Bank 1: 0.0 %
PID07 Long Term Trim - Bank 1: -0.8 %
PID12 Engine RPM: 720 /min
PID13 Vehicle speed: 0 km/h
Mode 03: Emission related fault codes
Address 10 (Engine): 2 Faults Found:
P0030 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction / Open Circuit
P0135 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
Address 01: Engine Labels: None
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT 0003
Coding: 10710
Shop #: WSC 06435
VCID: 387B2CD3184894E
WAUZZZ8LZ1A021420 AUZ7Z0Y1555840
5 Faults Found
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-10 - Open Circuit - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-10 - Performance too Low - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 35-00 - Open or Short to Plus
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 06435
VCID: 3E773ACB3A6CAAE
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0101
Coding: 00041
Shop #: WSC 06435
VCID: 2D550D87E70A216
Address 15: Airbags Labels:
VCID: 55A58567AC1A496
Note: Excessive Comm Errors
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 L
Component: AB-KOMBIINSTR. VDO D12
Coding: 01444
Shop #: WSC 00001
VCID: 3C7330C32C70B8E
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F49E74F9DA6C36
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 06435
VCID: 2F69178FED06536
3 Faults Found
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0CB24B360583CE
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 06435
VCID: E5C535A77F7A596
End ---------------------------------------------------------------------
Most help would be appreciated.
cheers Olly
17:02:49 Group 032
0.6 % Lambda
0.0 % Lambda
Bin. Bits
Bin. Bits
17:00:41 Group 115
720 /min RPM
15.8 % Load
17:08:03 Group 002
720 /min RPM
15.8 % Load
2.17 g/s Mass Flow
17:08:57 Group 001
720 /min RPM
96.0°C Temperature
-3.9 % Lambda
00111111 Bin. Bits
17:11:13 Group 031
0.977 Lambda Factor
0.992 Lambda Factor
Bin. Bits
Bin. Bits
Fuel System: Passed
Coding: 10710
Shop #: WSC 06435
5 Faults Found
Coding: 18448
Shop #: WSC 06435
Coding: 00041
Shop #: WSC 06435
Coding: 01444
Shop #: WSC 00001
Coding: 15178
Shop #: WSC 06435
3 Faults Found
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 06435
cheers Olly
