to front mount intercooler or not!
g60leigh Feb 19, 2008
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Thinking of getting a autobahn88 fmic. but not sure if I would be wasting my money?
    I have a 96 a4 1.8T. it is aeb engine. revo chip. n75j valve. forge recirc valve. k&n panel filter and jetex stainless exhaust.
    car is running 11-12psi boost
    Do you guys think I will get any benefit from a front mount intercooler (standard bumper)
    Thanks people
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,772
    32
    Have you run Vagcom logs to see what your IAT's are with your current setup?
    I wouldn't have thought an FMIC would give you much benefit unless you are running high boost or living somewhere with high ambient temperatures.
  3. TFSI
    TFSI Born to Fish
    540
    52
    The engines i work with boost at 2.6 Bar (36-37 psi) and the intake manifold air temp is normally around 25 centigrade. thats with a front mount intercooler.:) :) :)
  4. macca
    macca Member
    525
    i have similar setup and yes it made a difference, i think most noticably will be in the summer as my intake temps felt high when driving.
    i have cut away front of bumper though so fully exposed, have got an s4 bumper going on once i get the new mounts.
    not sure how good it will be on a non cut bumper.
  5. 96a6v6
    96a6v6 Member
    76
    If you afford a FMIC, then go for it, Im sure you will notice a difference :)
  6. Markey
    Markey Active Member
    2,175
    It will lower temps best to try and do before and after tests to be sure, also looks cool and they are not that expensive.
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    proper ducting lessens the slice and dice approach to your bumper.
    it certainly made a difference on mine
  8. g60leigh
    1,674
    207
    Going to stick with standar one for now and spend money elsewhere. any sugesstions? :jump:
  9. Bong Water
    Bong Water In two minds
    786
    Turbo inlet pipe
  10. g60leigh
    1,674
    207
    the one from the airbox, with all the off shoot pipes? I have ordered Autobah88 kits for both sides of intercooler
  11. Bong Water
    786
  12. g60leigh
    1,674
    207
  13. docurley
    4,071
    85
    There is also a set of pipes in the Classifieds section.
  14. g60leigh
    1,674
    207
  15. Markey
    2,175
    Should be posting them tomorrow mate :)
    The vacum hose was not inculded in this as per the pics but i will chuck on in as i found it in the garage yesterday.
  16. g60leigh
    1,674
    207
    great stuff mate. Thanks
