To do list...
rossbrownlee Sep 1, 2009
  1. rossbrownlee
    rossbrownlee Ross_S4
    719
    Hi all.
    Other than the normal servicing, I am thinking about doing / having done the following as I have no record of when they were last done (2000 V-Reg, 106k miles):
    Replace Haldex oil + filter,
    Replace fuel filter,
    Change brake fluid,
    Check Cambelt.
    Anyone suggest anything else?
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
  3. A3tell
    A3tell Member
    239
    yeh, would def go with water pump, if you are going to cange cambelt!!! cos if it goes (and it will go, mine just went on just under 100,000 miles- cost 350 cos had to have cambelt and tensioners replaced.) dont want to do same job twice!!lol
  4. abdus
    abdus Top Gear VCDS Map User
    1,827
    if you have no previous records on service done, just do not simply check the cambelt. Get it changed and as said above, get the water pump done at the same time.
  5. rossbrownlee
    719
    I know the cambelt was done at about 75k hence the check as opposed to straight replacement, how often should they be replaced?
    There was no mention of the water pump getting done at the same time.
  6. voorhees
    16,249
    2,072
    Audi originally said the cambelt needed replacing every 120k but changed it to 60k or 5 years whichever comes first.
  7. rossbrownlee
    719
    okay thanks everyone for the info.
  8. Dani_B19
    9,380
    402
    Mine was meant tobe done at some were between 60-70k cant remeber exactly and it wasnt so wouldnt just trust whats wrote on a piece of paper.
  9. voorhees
    16,249
    2,072
    Its definitely 60k as I had mine done at an Audi dealership,don't confuse anyone Dan
