Tiptronic problem
leedov Apr 6, 2013
  1. leedov
    leedov New Member
    A4 3.0 quattro 78,000 miles
    2005 tiptronic transmission problem.
    No reverse gear. car stuck in limp mode.
    Car been in garage today. Fault codes thrown up do not indicate any specific problem. Worst fear is that it is the module within the gearbox.
    The fluid level is fine. Has anyone heard of a similar problem? Will a fluid change help matters? Any advice would be great.
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    did they connect to gearbox ECU? they can check if the solenoids are working or not, Did it say intermittent signal?
    What did they use to check the codes with?
  3. gen.heinz guderian
    1,346
    126
    Do you get the PRND flashing on the dash clocks?
  4. leedov
    leedov New Member
    PRND not flashing but all lit up a solid line.
    Bosch diagnostic through the obd i think
  5. shariain
    shariain Well-Known Member
    1,182
    190
    I have recently had dsg problems on my 3.2v6 a3 and the fault code I got is-
    17085 - Transm. Control Module Range/Performance (SAE) or Control Module Defective (VAG)
    P0701 - 004 - No Signal/Communication - Intermittent
    I got the dsg serviced and I thought everything was ok until it jumped out of gear and the dis prnds started flashing.
    Put the car in neutral and turned the car off then restarted it and the dis was not flashing and I could select the gears again but sometimes only for a short period of time and then other times it will not do it again for the rest of the day.
    I posted in a thread about this earlier today there is a company within that thread that can rework your gearbox ecu.
    Company
    http://www.ecutesting.com/
    Thread
    http://www.audi-sport.net/vb/a3-s3-...mechatronic-issues-any-ideas.html#post1838132
  6. NHN
    29,300
    1,703
    Also calibrating the gearbox with vcds or dealer is a must before condemning.
  7. shariain
    1,182
    190
    NHN would have thanked you but on iPhone so a like will need to do. :)
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,120
    2,577
    I've thanked him for you. :thumbsup:
  9. shariain
    1,182
    190
    Well since getting the dsg serviced it has only jumped out of gear once so hopefully that's my problem sorted. Going to go back to the Indy and find out about getting the dsg reset. Just hope that's me sorted but no doubt I have spoke to soon.
  10. leedov
    leedov New Member
    Car is now in Eurotronic in Rosyth...............so fingers crossed. Everyone i speak to says it could be gearbox module. I don't know how
    much how much of a repair that is. But it will be sore i'm sure
