Tiptronic display PRNDS blanking out (Allroad 2.5TDI, 2004)
ms1083 Jan 2, 2012
  1. ms1083
    ms1083 Member
    148
    QUite often now when I start the car and select drive or reverse all the PRNDS blank out. Its gradually happening more & more. Car drives fine but cruise control & the tiptronic switches on steering wheel dont work. If I stop the car and restart it normally works like normal and nothing blanks out. Also tends to keep working like normal for the day from then on. Done a fault check:
    18161-163 KWP1281
    F189 triptronic switch static
    P1753
    I have checked the tiptronic switch module, the sliding cover looks fine & the magnets are all in place like normal.
    Tends only to go wrong first thing in morning, especially when cold & wet.
    Wondering if the most likely thing is the actual F189 electronic switch circuit board & being affected by dam/cold. Dried it out with some mets & WD40 the connectors but still going wrong.
    Replacment F189 switch just over £100 - very tempted to buy a new one and hopefully problem fixed but any comments/suggestions before I splash out?
