Tinted Taillights?
Toxik-Signal Jan 22, 2007
  1. Anyone here have any pics of A3s with Black tinted taillights? Thinking of doing mine :yahoo:
  2. garratt83
    garratt83 Member
    244
    NOOOOOOOOOOOOOOOO don't do it. Stay with the OEM, don't join the darkside
    :haudrauf: :haudrauf: :haudrauf:
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,093
    227
    Do you mean your spraying them? Got to agree, not so sure that'll look too good!
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    This is normaly done to fiesta's and the like, and it ends up looking like its covered in some wierd matt finish that looks like dust. and you can't see the lights properly either
  5. j4g3d
    j4g3d Member
    246
  6. rodenal
    rodenal Active Member
    1,992
    God no dont do that to your rear lights.
    The fronts can look good with a bit sprayed, but your better doing it yourself
  7. fingermouse
    fingermouse thats me
    4,027
    120
    Do the a3`s need there own section now?????? OMG!!!!
  8. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    No, just a chavtastic section!!!
  9. silver75
    silver75 Big Ron
    3,265
    S car snobbery :beee::mad:
  10. Peloton
    Peloton Member
    354
    lol I've got the smoked rear clusters on mine.....
    I think they look fine on silver! :mad: lol
    Oh they were bought off the shelf like that, not sprayed.
  11. fingermouse
    4,027
    120
    lol no its just I hate tat
  12. dubhyper
    dubhyper Illegally Street
    128
    here here,, well said..
    but that said, dont spray them, its looks cheap and tacky - spend the extra dough do what peltons done, get a decent set off the shelf
  13. Ok thanks for the opinions everyone, it's sorta put me off the idea now which is probably best :D
    I'm definitely doing my windows though :eyebrows:
  14. j4g3d
    j4g3d Member
    246
    im keeping standard ones. even tho pelotons looks good. altho i MAY tint them full red with the proper tail light stuff.
  15. silver75
    silver75 Big Ron
    3,265
    ...get that sticker off and put an Audi-Sport one on
  16. Peloton
    Peloton Member
    354
    lol Don't worry it's an old pic. The stickers been swapped for the AS.net one for quite a while now although it's on the other side. Plus the daft shark fin ariel's been swapped for a 100mm 'tweety' job.
  17. leecs3
    leecs3 thinking about stuff
    604
    i'm thinking about tinting my rear light to knock back the bright red abit. Had a little play. What do you think?
    standard
    red bit tinted
    all red
    all red then knocked back with black
  18. rodenal
    1,992
    I'd keep em as they are, the slightly tinted lights will take away from the shine of the car when clean, and the all red and red with black just look like pre-facelift lights
  19. I went ahead and did this after photoshopping a few pics and asking some people's opinions (yeah I know I said I wouldn't).
    If you want to go ahead and tint your lights with a nice finish (that isn't dull), then follow this little guide I wrote especially for you! :icon_thumright:
    You need:
    Washing up liquid
    Wet and dry (very fine sandpaper)
    1-2 cans of tinting spray (such as 'Tail light tint' from Motorworld).
    Clear Laquer spray (also available from Motorworld).
    Car Wax & cloth
    1. First of all take the tail lights out of your car by undoing the 4 bolts on the inside of the light (these were 8mm on mine).
    2. Clean the tail light lenses with washing up liquid and water to get rid of any muck on them.
    3. Wet the wet & dry paper and use it on the tail light lens until the lens looks all dull (don't worry about this - the clear laquer will make it all nice and shiney again) - this helps the tinting spray to stick to the lights easier.
    4. Clean the lens with water (to get all of the sanding **** off it) and then leave it to dry completely.
    5. Find a well ventilated area where dust and grit isn't going to get kicked up, shake up a can of tinting spray and then start spraying very thin layers of tint onto the light.
    You should apply very thin layers to get the best results because if you spray too heavy then the tint may run (I probably did about 20 layers overall).
    Aim the can away from the lights as you start spraying to ensure that you don't get big blotchy patches. Also it's best to spray both lights at the same time to make sure you get the same level of tint on both lights.
    6. Once the lights are as dark as you want them (I stopped when mine looked black in normal lighting conditions), then leave them to completely dry for a few hours.
    7. Once you've given them a few hours, it's time to apply the clear laquer, this will protect the tint from rubbing off and give you a nice shiney finish. Apply the laquer in exactly the same way as you did the tint (thin layers at a time and leaving 15-20 mins between layers). Once you've used about half a can then let the lights dry for about 12 hours (apparently the laquer is not completely effective until then).
    8. Now break out the car wax and wax your newly tinted lights before reinstalling them into your car.
    And that's all there is to it! :)
