Update time, after having a map etc i need to get a FMIC and was the last engine mod on my list, i was going to go the welly cooler route with my own piping as i though it would give me better results and probably easier to fit, but i was also watching a purpose built toyosports one on eBay that came with n75, dv and map sensor already to go ended up getting it for £200 delivered so cant really complain its 64mm bore and i can always upgrade the core later on i was well happy till i came to fit it :/
Got delivered and didnt look that well packaged so was a bit worried
Got the box opened and was packaged well inside the outer box so all good, came with pipes, reducers, couplers, and clips all of which arernt the best quality but if i went forge for quality i paying and extra £400 so it does the job.
started by taking out the battery and filter etc to make room
took off the original boost pipe from the turbo and started to work it all in
hung the core in the center using two long bolts going straight through the crash bar
worked the drivers side up and it wouldn't fit with the head light in so had to really squeeze and move the pipes about till eventually had enough to grip it to the throttle body, it looks a bit bodged but it on there solid and would be amazed if it came off
atm the pipe is squashed up against my hid wires hoping it wont get hot enough to melt them.
worked the pipes from the turbo end and was again a tight squeze under the strut and above my oversized tip :/
ended up having to hack away at my heatshield as i didnt want to get rid of it
got a bit too trigger happy with the grinder
the hardest part was getting the pipe onto the core it was miles out so had to rework it again and finally got it... just
Dv and n75 connected up with a little trimming of the original hose's
Now ive just spent the whole morning trying to get the bumper on and it would not go, was miles out i think where i fit the core so far forward
however as with the rest of the build thread i went the route that most people will find fugly
. will take some pics tomorrow also need to sort out my exhaust as its blowing from the center clamp and a new gasket on the down pipe
