Timing or cam sensor please help
S3ben Jul 25, 2013
  1. S3ben
    S3ben Member
    50
    Hi to all. I've got a s3 2000 apy and has bad judder/ misfire. Scanned with vag-com and got code 17745/p1337. I've changed the cam sensor and check power to the connector reading 5v I have not checked the switch wire. The cambelt was change about 3 weeks ago could it be the timing out????
  2. <tuffty/>
    21,255
    3,880
    17745/P1337/004919 - Ross-Tech Wiki
    17745/P1337/004919 - Camshaft Position Sensor (G40)
    17745/P1337/004919 - Camshaft Position Sensor (G40): Short to Ground
    Possible Symptoms
    Malfunction Indicator Lamp (MIL) active
    Possible Causes
    Camshaft Position Sensor (G40) faulty
    Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
    Possible Solutions
    Check Camshaft Adjustment
    Check Camshaft Position Sensor (G40)
    Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
    Double check the wiring... its shared wiring on these... if you unplug the sensor, turn on ignition, clear codes and turn the engine over do you get an open circuit fault code instead? if you do then I suspect its a wiring fault in the loom somewhere... no other fault codes?
  3. S3ben
    S3ben Member
    50
    Hi thanks for quick reply. I get the epc light come up then clear all codes then goes away. Yes it's the only code that I get. I shall try what you have said and post my results. Once again thanks
  4. S3ben
    S3ben Member
    50
    I'm getting code 17746/p1338-35-00-- open or short to plus. Is this a big problem I've got on my hands??? Also is it safe to drive with this fault??
  5. andyrg
    andyrg New Member
    10
    Ive got a cam sensor for one ;) drop ne a pm 10 £ posted
  6. S3ben
    S3ben Member
    50
    Thanks for the offer but I've tried two new ones just in case one was bad.
  7. Broken Byzan
    13,237
    465
    badly timed engine. Take it back to the garage to get it checked.
  8. Broken Byzan
    13,237
    465
    Had this with hollies car, it was a timing error. It couldn't see the cam where it expected so it threw the fault. No idea why it didnt throw the correlation code, have to assume it was related to VVT. I think it was cam to cam over crank to cam. But given they have recently changed the cam belt, my bet it the error is there.
    <tuffty/> likes this.
  9. <tuffty/>
    21,255
    3,880
    I remember this now yeah... good spot dude :)
  10. S3ben
    S3ben Member
    50
    I was thinking it may be timing ill give them a ring in the morn. Thanks for your advice.
  11. S3ben
    S3ben Member
    50
    Dose my apy have vvt-I? If not could timing be the strongest possibility???
  12. superkarl
    superkarl MAN OF STEEL
    9,482
    2,435
    No it doesnt have vvt
  13. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I had this and the belt was out, god knows why it throws a short to ground code, anyway corrected it and was perfect..
