Timing Belt tips
allymorrison70 Nov 22, 2013
  1. allymorrison70
    allymorrison70 New Member
    19
    So i'm fitting a timing belt kit and water pump tomorrow, its a 55 plate a3 TDI sportback. Anyone got any tips to help me on my way?
  2. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    Did you get a new tensioner as well?
    One tip is to get a marker pen to mark up where the pulleys are in relation to each other so that when the new belt goes back on you can see if everything lines up and nothing has moved.
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    If you need to, go to Specsavers first....:rockwoot:
  4. allymorrison70
    19
    Yeah, got the belt, two idlers, tensioner and water pump.
    I've got the cam locking tools so i think i've got it covered. Just wondering if anyone had managed to make the job easier.
  5. Lewis583
    956
    91
    The offside engine mount bracket can be a pain in the arse to get out, so takes a bit of fiddling.
    The correct way of doing it is to lock the cams in place with a pin in each pulley and to then slack the 3 bolts on each pulley. This allows the cam sprocket to turn while keeping the cam in the correct position. This is to allow an even spread of tension on the belt when tensioning. The 3 bolts are then re-tightened.
    Otherwise you can get away with the old tippex method, just makes sure the belt is taught between the pulleys on the non-tension side.
    Everything else is pretty straight forward and remember, if there is new bolts/studs in the kit USE THEM!
