time to buy some new snow foam
einonsy Apr 6, 2011
  1. einonsy
    einonsy Member
    66
    Hi all!
    sorry if this has been posted 1000 times... im after some recommendations on what SF you are using at the moment, ive had super snow foam however, im looking for something that can give a thicker foam with less drip...
    if its out there.. i read a long time ago that there was a foam that would stay on for 15 -20 mins with no drip?
    cheers in advance!
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
  3. absolutes3
    absolutes3 Member
    Ive just started using the new chemical guys no touch snow foam and really like it. Can be bought for £20 for 5l.
  4. deanski
    deanski wax on, wax off
    369
    try meguiars hyper wash. it will double as a foam and a shampoo.
  5. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    I use Meguiar's Hyperwash with a PA Foam Lance.
    The thickness of foam is determined by a few things. The product used, the foam lance itself and also the flow rate of your power washer.
    Try using a little more product to get a thicker foam however even the thickest of foam starts to drip away after about 10 minutes.
  6. Aaronipswich
    Aaronipswich Member
    I'm new to detailing
    Is snow foaming a good way to lift the dirt off the car
    Also what chemicals would you suggest for a beginner
  7. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    I found that standing further away helps in 'dropping' the foam on the car.Too close and it sprays off.I find megs hyperwash is good for loosening crud, but thats about it.As a foam alone it cleans nothing...the grime/film still there so itll need a normal two bucket wash as well
  8. Grant
    1,206
    118
    Snow foaming shouldn't be thought of as a quick alternative to washing a car. The purpose of it is to loosen dirt and make the washing process easier and less likely to create swirls/scratches.
    Think of snow foam as like soaking a casserole dish to loosen the baked on remains. You still need to wash the casserole dish afterwards. Of course, you don't have to soak your casserole dish if you don't want to... but it would take more effort to clean it properly.
  9. Farhan
    Farhan Active Member
    1,234
    57
    auto brite have a new foam out called magi foam its meant to be proper thick
  10. John @ PB
    John @ PB Member
    360
    What he said: foaming is a 'pre-wash' designed to loosen dirt, soften dead flies etc, before you start the proper handwash. It will remove some grime and the more you get off before you start hand washing, the lower the risk of wash marring/swirling.
    We always rinse the car first, then foam, then rinse, then start handwashing.
    Our guide is here: Safe Washing And Drying | Car Care Advice | Polished Bliss
    We recommend Meguiar's Hyper Wash Meguiar's Hyper Wash | Meguiar's Car Care & Detailing Products (due back in stock very soon) as it's almost unbeatable in terms of dilution and won't strip waxes or sealants.
