Tie rod/track rod end question.
ArtBet Dec 23, 2013
  1. ArtBet
    ArtBet Member
    46
    Hello everyone and merry christmass!
    My car is developing a knocking noise when turning the steering wheel from side to side when car is stationary.
    I was told that those could be tie rod/ track rod ends.
    Just wanted to hear what you guys think before buying the parts.
    Kind Regard
    Arthur
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Could be anything to be fair, best bet is to get it diagnosed.
    Dead / worn steering racks can also do this.
  3. spartacus68
    spartacus68 Active Member
    160
    35
    Easiest thing to do is jack it up and hold the wheel at a 10-to-2 position. Rock wheel from side to side, the tie rod will be easy to spot if it clunks.
  4. ArtBet
    ArtBet Member
    46
    Thank you for replys!
    It also knocks when turning in to drive way on full lock.
    I'll take a look after christmass.
    Kind Regards
    Arthur
  5. spartacus68
    160
    35
    Full lock noise could also be worn CV joint. Check the rubber gaiter hasn't torn.
