ticking from front right
- Sep 10, 2003
  1. Guest
    The SLD 920 is "on" all the time, so depending on the amount of time spent in your car depends on the amount of time it will last for as the LED's will eventually start to fail. (Normally one month after your warranty runs out /ubbthreads/images/graemlins/rant.gif) Also they "tune" the infa red LED's to emit a signal to jam the laser gun which is why they need two heads to get enough "power". The LRC100 only fires back when being fired at so If you are comming down a road slowly and plod zaps you with his gun you might jam him for say 200M then it will go off the SLD920 will be jammimg him when you pull along side for a chat (The guy who got arrested in wales was using a SLD920). IMHO the LRC100 is a nicer unit and better made for the same money as a Snooper. Also their little episode of intefering with Sky put me of a bit as well !
    To sum up LRC 100
    It can open your garage door
    Contains a Laser Diode
    Better Construction
    Only on when needed
    Same price as SLD920 (Cheaper when bought from me !)
    To be fair 2nd place will go to the SLD920 and the Blinder M10 (Both the same unit)
    Tim
  2. Guest
    Glad you are happy with the Micro !
    Tim
  3. JayA4Turbo
    JayA4Turbo Member
    117
    [ QUOTE ]
    Tim
    [/ QUOTE ]
    Where would you put the aerial in an M5?
  4. Guest
    On the dash somewhere, or if you have climate comfort screen on the rear shelf. The micro comes with a 2M aerial cable as standard, if you want to munt it on the rear shelf you need a 5M (NO CHARGE !)
    Tim
  5. EoD
    EoD New Member
    24
    hiya all
    just a quick FYI for anyone who has experienced this...
    we noticed a ticking coming from the front right side of our car when idling - sounds like a pocket watch on steroids...tick tick tick tick!
    well as it turns out its an easy fix and its something to do with a gas release valve. (not a tech head so thats how id describe the thing)
    there you go, saw someone with this problem a while back - hope this helps anyone who notices it.
    Ed
  6. foolish3uk
    foolish3uk Member
    455
    it is your activated charchol filter and nothing to worry about!
  7. RacingTeatray
    RacingTeatray Freezing in Moscow
    249
    Is that so? I've noticed this on my car and worried about until I got so used to it I didn't notice it any more.
