"Thunking" in to gear
wuta3 Dec 18, 2013
  1. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Hi guys, Recently encountered an issue with my A3 (2.0tfsi, manual). At low-ish revs, changing down in to 2nd or 1st gear (for example when parking), when the clutch engages the whole car "thuds" in to gear. It feels almost like the engine shifts and makes a dull audible thud. It doesn't matter how slowly I bring the clutch up, but as soon as the biting point is reached it does it. If I change down at unnaturally high revs it is OK. Doesn't feel normal. I have had a Sachs organic in for 6 months and has been fine, recently popped TBE on. Any ideas?
  2. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I get a bit of a clunk from time to time too mainly changing to second or third if I let the clutch up too sharpish. Think it might be the gearbox mount
  3. wuta3
    1,124
    347
    Once im in gear, its fine going clutch up/down, it's just the initial change at low speed/low revs. Its a bit of a lurch of engine braking but quite violent. Feels like a mount of some kind, or something in the front end shifting. Once the clunk happens, all is normal. The drive to the wheels doesn't surge as far as I can tell. Feels like the clutch "snaps" engaged and moves something heavy.
    Odd
  4. OVRA3
    1,079
    80
    Pretty much the same no surging to the wheels it's just that initial bite that makes the clunk but I can minimise mine by being real gentle with the clutch.. It is odd was going to wait to see if it gets worse as it's hard to pin point what it is
  5. wuta3
    1,124
    347
    When going 3rd->2nd, if I treat it like going N->1st and bring the revs up a bit it is OK.
    The clunk doesnt feel like anti-stall or too low revs, just a mechanical "something" at the frontend. The part of me with mechanical sympathy goes "that aint right".
  6. OVRA3
    1,079
    80
    Same it's a dull clunk not a knock like something very heavy moving forward. Something is a miss sure it's a mount of sorts
  7. wuta3
    1,124
    347
    mine seems to be intermittent / in a very small range of revs/speeds/clutch movements. Was trying to reproduce while out this evening and it seemed fine. Anyway, at least im not the only one or my clutch isn't going lol
  8. OVRA3
    1,079
    80
    If you find out what it is let me know and I will do the same :)
  9. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    If either of you find out what it is, let me know as your problems sound just like mine in my A3.
    Always get a thud when clutch bites going into 2nd etc. Seems to be worse going from 1st to 2nd and 2nd to 3rd.
  10. OVRA3
    1,079
    80
    If you are driving spiritedly I bet damn glad I'm not the only one
  11. wuta3
    1,124
    347
    I dont get clunks/mass shift changing up, just down at low speeds and low revs.
  12. wuta3
    1,124
    347
    What clutch you running? Might just be the nature of our clutches?
  13. leeds2592
    1,399
    222
    Just standard clutch mate.
    Doesn't bother me too much but I've tried to find out what it is the past and most replies to threads on here tend to point to gearbox mounts.
  14. OVRA3
    1,079
    80
    Standard clutch and I agree doesn't worry me but I think it's gb mount
  15. Andy1608
    Andy1608 Active Member
    615
    203
    43
    Mine does the same on a 12 plate too. Low speed and only between 1st 2nd and third and also only seems to do it from cold
