Thule Roof Bars
ScottD3 Jun 25, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    Anyone out there run Thule roof bars on their avant?
    With the 757 feet?
  2. jcb
    jcb Active Member
    4,132
    13
    yes but not those feet
    mine are the same profile but lock on the end of the bar rather than on the side of the feet.
    bulky solution to a problem that didnt exist by the looks of it
  3. s4best4
    s4best4 Member
    71
    Yep I do.
  4. ScottD3
    15,164
    1,123
    what feet and bars?
    got any pics?
    what bars?
    have you had any issues?
    I'm in talk with Thule at the moment bout the damage the feet caused to my roof.
    Wondering if it happened to any one else.
  5. s4best4
    s4best4 Member
    71
    I've got the oval type bars. Ive had no problems with them-what have the feet done to your roof??
  6. ScottD3
    15,164
    1,123
    Took the paint off.
    I followed their instructions, the standard Audi fitments points and moving them all around a bit to get my roof box to fit and it appears they sat/sit to far forward and took the paint off where the feet touches the roof.
    Bit of a pain but nothing massive.
    I've emailed Thule and they've asked for images and more details about the car, I've given them all that just waiting for a reply.
  7. s4best4
    s4best4 Member
    71
    The feet clamp around the roof bars, so have you had to mount yours so far forward? i just clamped mine (3 bike racks) to where they sat in the middle of the car.
  8. ScottD3
    15,164
    1,123
    I use a roof box and cause of its size I need to mount them that far forward and back.
    I can adjust them a little bit but it will still rub or the roof box will sit to far back and hit the tail gate or the bars and box will sit in the middle of the rails and I don't really want to push it holding up 100kg of weight.
    I guess the point is that I did it as per the instructions of both Audi and thule and it did damaged my car. :|
  9. s4best4
    s4best4 Member
    71
    Yep thats not good...Hope you get a result.
  10. jcb
    jcb Active Member
    4,132
    13
    that sounds weird
    I have never mounted mine in the recommended spots (one reason is that I would think closer to the rail post rather than in the middle has to be stronger)
    how does it touch the paint?
    I had 400kg of IKEA wardrobe on the roof once.....
    they are stronger than you think!
  11. ScottD3
    15,164
    1,123
    That's my thinking. I would not want to trust it out in the middle or away from the recommended points.
    wow, 400kg is allot, I would never carry that and would not really want to push it that far over the weight limit.
    Here's a couple of images.
    Just a side note just in case Thule or any one reads this.
    I'm not bad mouthing Thule, that not my intention.
    I love their products (hence having bars, box, feet and key set), I just want to tell them about this.
  12. patTTpoa
    patTTpoa Member
    793
    Just seen this Scott,
    My old roof rack for my B5 passat (same make) but the old style had a lot of clearance (maybe a fat finger) between the foot & the roof from end to end (bars not rack) as I use to carry ladders (double 12's).
    I hope you get this sorted.
    Pat
  13. jcb
    jcb Active Member
    4,132
    13
    bet those are not for your car/model
    way more clearance on mine, like above, except my fingers arent fat...
  14. ScottD3
    15,164
    1,123
    We'll see what happens.
    Its been passed to head office in Sweden
    They are.
    I've checked it several times before they was bought and again after.
    Thats going by Thule's site.
  15. aragorn
    18,579
    868
    Wrong feet in the box?
  16. ScottD3
    15,164
    1,123
    That is an option but they look the same the pictures of 757 feet.
  17. spartacus68
    spartacus68 Active Member
    160
    35
    The feet don't look right. Here's mine with the aero bars.
    The feet are model 755. I can't get a finger under mine (and no I don't have butcher's fingers), but there is a gap and it doesn't rest on the paint.
    Someone mentioned 400kg... jeez that's way too much weight. Sure the car will carry it, but if there was an accident then the insurance company would wash their hands of it. The load is only as secure as the fixing points, and the breaking strain of the straps. On the A4 avant - the maximum roof load weight is 75kg.
  18. brasiliangringo
    brasiliangringo Member
    626
    10
    Ive used thule gear on an A3 (L) with the 750 foot pack and with my old S4 Avant with the rectangular cross bar (so i could swap between the two cars and just change the foot pack). Anyway i have always been mighty impressed. Been at 80/85 with two 15 foot kayaks for 9 hours driving and once had to boot it in the S4 from 1st off a round-about to get into the correct lane - fastest Kayaks around!!
    Anyway, i have two roof rails for sale if Thule dont cough up which i have just removed from a 2000 A4 2.8Q i am breaking.
  19. brasiliangringo
    626
    10
    400Kg on the roof is mad...
  20. spartacus68
    160
    35
    Should have mentioned - the Thule system with the 755 feet were previously on my 80 Avant (B4). Straight swap to the B5.
  21. brasiliangringo
    626
    10
    Yep they are the ones i used no problem 755s now called 757s (not sure of the difference) but they are 30 squid on ebay.. Very impressed with my thule gear and all had cheap through ebay.. My friend now uses them on his 59 plate passat so quite versatile !
  22. ScottD3
    15,164
    1,123
    Going by Thules site and a couple of their dealers the 757 are the correct feet.
    Thule not said they are wrong for my car.
    Still waiting for their HQ to get back to me.
  23. ScottD3
    15,164
    1,123
    They finally got back to me.
    Sweden is on holiday so Germany took their place.
  24. ScottD3
    15,164
    1,123
    Got a email from Thule this morning.
    They mentioned about the 775 feet.
    Just need to see what they want to do about it.
    Offer them to me in exchange for my 757s, give them to me for free since their old kit damaged my roof and not worry about the repair or make my pay for the 775s (they stopped selling them in 09) and keep my 757s.
    I'll see what they say.
    albeit slow they seem to be ok so far.
