Ths engine mounts or Vibra Technics Engine Mounts
Kelza Feb 24, 2012
  1. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi i,m on stage 2+ on my s3 8p3 and have the ths mounts new sitting here but i,ve just seen the vibra technics mounts they look amazing , which ones are you using, or perfer... Cheers..
  2. Kelza
    3,078
    604
  3. Kelza
    3,078
    604
  4. Kelza
    3,078
    604
    These vibratechnics are the ones i,m going for,,also is 2 lower mounts needed on the s3 8p3?
  5. S3Alex
    10,641
    4,698
    I've got the VWRacing mounts here which I believe are Vibratechnics.
  6. Kelza
    3,078
    604
    Like these ones alex , also do i need 2 sets of lower mounts ,and what ones u using alex , race Or fast road mounts?
  7. Boydie
    Boydie Boycie VCDS Map User
    3,327
    423
    Price for each brands lads? A worth while mod???
  8. Kelza
    3,078
    604
    Hi boydie depends as some people dont bother , but while i get my clutch done i,m going put better mounts in ...
  9. quattro81
    quattro81 All the gear.. No idea
    970
    90
    I had vibra on my TT and they were awesome, have had no experience of THS but can definitely say had no probs with vibra tech
  10. S3Alex
    10,641
    4,698
    If I remember,the VWRacing ones were about £500 all in,so not cheap but very solid.
    If you weren't going the whole Stg3/4 hog,the THS set are cheaper and effective.
    For any Stg2+ or above engine I think you need one or other of these to deal with the engine flapping around on the standard mounts.
    But....do be prepared for a lot more engine thrash.
  11. S3Alex
    10,641
    4,698
    Fast road mounts.....they're pretty hard but the race ones are solid.
    You really won't want those.....my Escort had solid mounts and it's like being a passenger in a cement mixer.
  12. Kelza
    3,078
    604
  13. tcardio
    tcardio Well-Known Member
    967
    277
  14. S3Alex
    10,641
    4,698
    Interesting.
    The only thing that would concern me is the bit about them being tested with a 280bhp car.
    The VWRACING/Vibratechnics mounts are very solid things.
  15. Kelza
    3,078
    604
    Hi tcardio hpa core interlock with the vt lower monts like below...:)
  16. Kelza
    3,078
    604
    Hi alex how you getting on with spec clutch ,, i may sell mine and go for a spec one ,so i,m ready for bt....
  17. tcardio
    967
    277
    yeap
  18. Kelza
    3,078
    604
    Hi mate yeah going get some vt mounts and hpa core mount ,just need to sell my brand new ths mounts first ,,thanks,,:)
  19. S3Alex
    10,641
    4,698
    In the middle of getting that together right now.
  20. Kelza
    3,078
    604
    I really do like the look of the spec stage 3+ clutch , did you get the steel Or aluminum flywheel...
  21. S3Alex
    10,641
    4,698
    Steel...bit heavier and better for damping vibrations.
    There was a problem with the first one they sent with tolerances on the splines so I'm waiting on a new one.
  22. Kelza
    3,078
    604
    Right ,wow, looking forward to seeing your updates on your build thread , i,m just sorting out a vw racing bbk set up :)
  23. S3Alex
    10,641
    4,698
    Thanks.
    I'll have some feedback on the clutch soon as the replacement part has arrived and will be going in shortly along with full boost.
