Throttle problem, please help
matt blowen Jun 12, 2014
  1. matt blowen
    matt blowen Member
    183
    Right guys if searched all over but i cant find a definate solution, when driving steady in 1st & 2nd gear say if i lift off the gas pedal the car bucks and and also when i slightly press the throttle it bucks real pain when driving in stop/start traffic. Its asif it happens when the throttle plate closes any ideas thanks,
  2. matt blowen
    matt blowen Member
    183
    I have quite a bit of side to side engine movement, would engine mounts be the main cause of my bucking?
  3. LynxE
    LynxE Member
    104
    14
    Could it be the throttle body sticking?
  4. matt blowen
    matt blowen Member
    183
    No buddy, cleaned and ive done alignment
  5. s-express
    s-express New Member
    13
    Try a new MAF first, then if its still happening, remove TB, split and clean up the tracks on the circuit board that the 5 contacts run over - they get a build up of carbon on them and this gives faulty resistance readings to the ecu.
  6. s-express
    13
    off my mrs A2 but you get the idea - the black area is carbon deposits on the 4 tracks (not 5 as previously stated).
  7. matt blowen
    matt blowen Member
    183
    I will try this, thanks
  8. matt blowen
    matt blowen Member
    183
    Do i have to remove the black cover thats on the TB?
  9. s-express
    13
  10. s-express
    13
    yep you do
  11. matt blowen
    matt blowen Member
    183
    Thats wicked thanks will TB cleaner be ok on the tracks?
  12. matt blowen
    matt blowen Member
    183
    Mine looks different inside, it has a big spring and also a coil spring.
  13. matt blowen
    matt blowen Member
    183
    Ive got stuck in and found 2 small tracks, i have gave them a clean with cotton bud and wynns cleaner, i will report back in the motning with the results
  14. matt blowen
    matt blowen Member
    183
    No change, at least ive learned someting new.
  15. lol4fun
    lol4fun Member
    190
    Mine does the same. Put a new engine mount on and no different. Possibly worn gearbox, bottom arms, drive shafts. Actually have you replaced or poly bushed the dog bone mount? That would cause similar issues and are known to wear out.
  16. matt blowen
    matt blowen Member
    183
    Ive put on a yellow powerflex on the dogbone mount to try and sort this but i dont think it has helped, i might try and tighten the long bolt that compresses the bush? Ill take a look at the bottom arms in the morning
  17. matt blowen
    matt blowen Member
    183
    I dont know of its connected but when i rev the car, as the revs fall just past 2k you can feel the car misfire or bump a little and the exhaust note changes?
  18. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Disconnect the MAF and try again.
  19. matt blowen
    matt blowen Member
    183
    Ive treid running without the maf and it runs lumpy and then dies? I was told this is normal on an agu engine code
  20. 16Klappe
    5,795
    1,186
    Yep. Totally normal.
  21. matt blowen
    matt blowen Member
    183
    *UPDATE* all sorted just changed my right side engine mount, and it drives spot on
