Throttle position sensor
Mickeybhoy67 Aug 28, 2008
  1. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Don't mean to be stupid but can anyone tell me where it is located on an Audi A3 98?
    Cheers an advance!
  2. HTC
    HTC Active Member
    3,428
    9
    It is incorporated into the the throttle body under the black plastic cover.
  3. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Is it easy to replace????
  4. HTC
    HTC Active Member
    3,428
    9
    Just to double check, you have a cable operated throttle, correct and you are getting some sort of error code relating to the throttle position sensor?
  5. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Yes that is correct
  6. HTC
    HTC Active Member
    3,428
    9
    Just checking it wasn't DBW.
    You could try disconnecting the battery for about 20mins and then re-aligning the throttle body. Do this by turning on the ignition without starting the engine or touching the throttle body. Wait for the high pitched noise from the throttle body to stop and then see how you go.
    If it's still not right then it's a new throttle body unfortunately as the sensor cannot be removed separately as far as I know.
    Is the car not idling or something?
  7. Mickeybhoy67
    Mickeybhoy67 Member
    45
    I took to a couple of garages, one of which was an Audi specialist in Duntocher who done a diagnostic which gave out the following faults:
    00518 - Throttle Position Sensor (G69)
    31-00 - Open or Short to Ground
    01087 - Basic Setting Not Performed
    27-00 - Implausible Signal
    00530 - Throttle Position Sensor (G88)
    31-10 - Open or Short to Ground - Intermittent
    Basically the car starts ok when I turn the key however it dies straight away. I have to keep my foot on accelerator for a few minutes to keep the revs up then car is ok however idle set usually at 1ish
    Mido likes this.
  8. HTC
    HTC Active Member
    3,428
    9
    Yup, sounds buggered. It will probably be a new throttle body then. The specialist should first check the wiring though, just in case its a wire break rather than a component failure. However, I suspect it's the latter.
    Have a look on Ebay as the dealer will want about £430 for a new one.
  9. Mickeybhoy67
    Mickeybhoy67 Member
    45
    Its not the throttle body as I took into my local garage and they tried another throttle body, and took another diagnosis which gave the exact same readings!!!!!
  10. Mido
    Mido New Member
    I have the same problem and I replaced the throttle body and it still the same
    if you fixed it please tell me how
  11. Mido
    Mido New Member
    same problem need someone to tell us how to fix it :(
  12. RGL
    RGL Free breather
    114
    As someone already mentioned, it is possible that the throttle body itself stopped working properly. However it would be wiser (and much cheaper) to first try to check all the wires running to and from it for splits or any other damages, since these "Open or short to ground" and signal codes have often to do with the wiring. Cleaning the throttle body can't hurt either but I'm pretty sure it won't fix those faults. Either it's the wiring or the throttle body itself has lived it's life. Just try all non-cost/cheap measures like checking the wiring, cleaning and re-aligning first.
  13. Mido
    Mido New Member
    I replaced the throttle body and these errors remained
    I checked the wires and it seems ok .. and all fuses ok and cleaned the throttle body
    I don't know what else to do
  14. Mido
    Mido New Member
    does Audi A3 1998 1.6 petrol throttle pedal has a sensor ??
    if it does where its location plz
  15. Nomz
    Nomz New Member
    Hi there,
    Please could you tell me if you solved this problem and how as I have an Audi A3 1.6 8L and every time I start the car it just does out unless I keep my foot on the pedal and rev it for about 5-10 mins before it finally sits idle. If you can help me I'd appreciate it very much. Thank you.
    OTE="Mickeybhoy67, post: 605014, member: 11907"]I took to a couple of garages, one of which was an Audi specialist in Duntocher who done a diagnostic which gave out the following faults:
    Basically the car starts ok when I turn the key however it dies straight away. I have to keep my foot on accelerator for a few minutes to keep the revs up then car is ok however idle set usually at 1ish[/QUOTE]
