throttle body
a4quat Mar 24, 2007
  1. a4quat
    a4quat Member
    374
    does anyone know if its easy enough to remove the throttle body just to give it a clean, i think my car is non dbw.
  2. dummi
    dummi smoking a6
    1,210
    4 allen key bolts, just get replacement gaskets before you start only a couple quid.
  3. a4quat
    a4quat Member
    374
    is there a gasket set you just ask for or do you have to ask for specific ones?
  4. dummi
    dummi smoking a6
    1,210
    you can check etka before, or just go to parts at audi and they will look through etka for you and give you the correct one for your version of the 1.8t
  5. a4quat
    a4quat Member
    374
    after using the search button:idea: ive found a few threads on this and the next thing ive got to ask is do i need vag com to reset the tps? or is this on dbw only? mine has a throttle cable going to the tb so im guessin mines ndbw?
  6. joost
    joost Active Member
    1,169
    Sounds like yours is nDBW. If you disconnect the battery before you remove the throttle body for cleaning, the TPS will automatically go through the adaptation when the battery's re-connected. Just make sure you don't try to start the car before it's finished fannying about.
  7. a4quat
    a4quat Member
    374
    another question then, are the stereos coded, may need to look make sure i have the radio code before disconnecting battery.
  8. petewon
    petewon Member
    529
    You shouldnt loose the radio code. Audi code the radios to the car apparently. I recently dissconnected the battery and didnt loos the code. Audi used to retreive the codes for free but I think they may have started charging for the service.
